smog check P0505 error code
Old 08-25-2009, 12:13 PM
cmlapaz's Avatar
i have a 2001 4runner sr5 4wd and i just got a smog check and failed due to a p0505 error. my check engine light was on at the time of the check, along with the vsc trac and vsc off lights, which is what gave me the error. on my way to get it checked, the lights turned off and i drove it for about 50 miles to see if it would reset and took it back to the smog check but the error code was still there. i had the throttle body cleaned and the iac valve gasket replaced and decarbed, drove it for about 70 miles and took it back to the smog check but i still got that error. anyone else run into this problem? the place where i had it cleaned quoted me about $280 to do a full system check to guarantee that it will pass but i wanted to see if anyone here can help. this is as specific as i can get as i'm not that savvy with cars. thanks.
Old 08-30-2009, 10:39 AM
eddieleephd's Avatar
http://www.toyotanation.com/forum/sh...d.php?t=156858
Iac idle air control issue Maf or tps? Iac valve?do the run down.
Old 09-24-2009, 03:58 PM
RuffRider's Avatar
Eddie,
Are you sure that is the thread you meant to post? It asks two questions - both of which are unanswered.
Old 09-25-2009, 09:08 AM
no it wasn't sorry. http://www.parksoffroad.com/tacomamo...de/cip0505.pdf
http://www.toyotanation.com/forum/sh...d.php?t=313317
http://www.toyotanation.com/forum/sh...d.php?t=263730
smthwsn357
05-01-2024 07:28 AM
jasonty
41
12-23-2018 01:00 PM
raptor510
02-17-2017 07:11 AM
nonstop
07-24-2015 06:29 PM
timmJ
07-07-2015 02:01 PM
Quick Reply: smog check P0505 error code
