slight rapid vibration when accelerating
Old 01-26-2005, 04:13 PM
Brendan's Avatar
22re. when i'm on the gas, i have a slight, but rapid vibration that i can feel in the steering wheel and see when looking at the rear view mirror. As soon as I let off the gas, the vibration is completely gone. Any clues?
Old 01-26-2005, 09:11 PM
NathanBERG's Avatar
Lightbulb
Well without feeling it, it's hard to know. But have you checked your Driveline??? I would go down on the old Girl and check for play in the Driveline.
Old 01-27-2005, 05:58 AM
kyle_22r's Avatar
could be a u-joint.
when i was doing my engine swap, i left the driveline hooked up to the rear diff. when i went to pull it off to have it balanced, 2 of the bolts were so loose i didn't need a wrench to get them out! both u-joints were toast, and one of the yokes was pinched so it had to be machined. ended up running me about $130 for all the work it needed.
Old 01-27-2005, 06:58 AM
phorunninduke's Avatar
U- joint. Check that its not binding or loose. They have some greasable fittings on em that you can lube up. At the very worse replacing them is fairly easy and cheap.
Flightguy
10-02-2015 05:34 PM
the_supernerd
10-01-2015 09:20 PM
hiluxinargentina
09-30-2015 05:51 PM
dbollier123
09-29-2015 05:23 PM
JPV
09-28-2015 03:15 PM
Quick Reply: slight rapid vibration when accelerating
