Slight engine knock, need opinions
Old 07-05-2012, 09:32 AM
Michaelh359's Avatar
I have an 01 Tacoma prerunner v6. 2wd. When at idle or no load on engine I get a small knocking noise, sounds like its coming from top of engine closest to driver side. When any load is on engine or I give the slightest touch on the gas the noise goes away. My truck has about 160k miles. And I am about to put 3000 into it ie arb locker, gears, and preventative maintenance items. I just want to make sure my truck is running solid before I throw money into toys. Or if this is something I should figure out first. I have checked valve clearance and all in spec. Noise does seem to increase with rpm I belive. And I think it might be getting louder but could be my imagination.
Any ideas on what it could be or diagnostic tips?
All help appreciated thanks!
smthwsn357
05-01-2024 07:28 AM
icentropy
09-16-2020 02:47 PM
thefishguy77
07-30-2015 10:59 AM
A2theK
07-12-2015 10:46 AM
skoti89
07-06-2015 07:45 PM
Quick Reply: Slight engine knock, need opinions
