Should I go to 35's !?
Old 12-14-2005, 08:54 PM
BajaRunner's Avatar
Hey I have a opportunity to get some used BFG mudders (315/75/16) for cheap.
I think with my 8" of lift I'll be able to clear them no problem... And, they will fill out the wheel well more nicely.
The only reason I dont want to get them is that I will not be able to afford a re-gear anytime soon. I mean, I'll have to eat top ramen for the next 6 months and ride my bike around town to save up.
I have the 4.30's factory gears right now...
I've heard of issues with the rack and pinion failing as well as broken front CV's but I dont have a heavy pedal... I drive slow around town and I wont be offroading on rocks.
What do you guys think?
Old 12-14-2005, 08:56 PM
marko3xl3's Avatar
I'd wait until you get enough money to do even more stuff...re-gear, SAS etc. etc.
35"'s will just put more stress on your drivetrain for no reason. Also, is it worth wasting tight money just to have your truck look bling? There is barely anywhere where you need 35" to off-road without rocks, if that made sense.
Old 12-14-2005, 09:17 PM
Good Times's Avatar
1. regear as I don't think you'll be a happy camper w/ those 4.30's. I'd say 4.88's would definitely make it more enjoyable to drive.
2. keep a few spare half shafts for good measure.
3. enjoy the ride!
Good luck
Old 12-14-2005, 10:19 PM
ErikJeanna's Avatar
Cool
Isn't this pretty much what everyone on this message board does? I know I fall into this category.
Old 12-14-2005, 10:21 PM
marko3xl3's Avatar
But you actually use whatever you have on your truck for the purpose. He said he won't be rock crawling, yet he wants 35's...I dunno. I do fall into that category somewhat, I wasn't trying to belittle him, but I am still not surviving on Ramen
Old 12-14-2005, 10:48 PM
BajaRunner's Avatar
If I were to crawl rocks, Id have a 1st gen straight axle POS or something. This is my DD and baja expedition truck
Old 12-14-2005, 10:56 PM
Fink's Avatar
It would definitely look better I would just hate for something to break...you have a sweet rig as it is...I have not researched it personally but I would make sure there is no risk of anything else breaking and then weigh your decision based on that.
Just my $.02,
Fink
Old 12-15-2005, 03:41 AM
Senior Member
jacksonpt's Avatar
The wear and tear would be a bigger issue for me than would be the gearing. I run 33" muds on 3.90s... it's not fun, never confuse it for a race car, but it's fine for daily driving. You'd be running 35s with 4.30s - I would think that would be similar in feel to my setup, perhaps even a bit better. I think people on the boards get to hung up on gearing for day to day driving.
If you can fix stuff yourself and have the time/money to do so, then I say go for it. If you'd have to have the shop/dealer fix things anytime something broke, then I'd say stick with where you are. The expense/hastle of having the rig in the shop more frequently would suck.
Old 12-15-2005, 04:04 AM
Intrepid's Avatar
I say get them, when will you run across another opportunity to get them cheap? Just put them aside for now and save up for better gears. Also, in regards to your 1st gen POS comment...I pity the fool that calls my 1st gen a POS!
ErikJeanna, Speak for yourself on the bling comment, or at least, speak for yourself and Lee...
Old 12-15-2005, 06:05 AM
ebelen1's Avatar
Isn't the stress on your drivetrain more related to the rock crawling and heavy pedal? If so and you don't do these things, do it. Your truck would look massive.
Intrepid, I'm sure your truck is a great offroader but like Erik, I'm into the bling. I'm pretty sure the jab at Lee was just that, a jab. He's posted a ton of pics of his truck going off-road on this board. Just cuz his truck is super clean, don't HATE!!!
Old 12-15-2005, 06:41 AM
HOJU's Avatar
As far as breaking stuff like CV’s, power steering, etc… I haven't had any issues with my 35's yet, and I drive it hard. In my opinion 35’s aren’t the big barrier that everybody thinks… Sure everyone with 35’s need to make a little room here, a little room there, for when you go crawling, but it’s not that big of a deal. With your 8" of lift you might be ok, you never know? I don't think it's that much different than going from a 31" to a 33"/285, everyone here knows the things that are necessary, and the things that are recommended, but not necessarily mandatory for making that jump. With going from a 33”/285 up to a 35”/315 it’s more of the same, it just involves a few more things that can usually be overlooked in the 31” to 33”/285 jump.
If you can get the tires for cheap, then do it.... If you don’t like the ride, you can always just wait until you have the money to re-gear. When I made that jump, I went- exhaust and tires, waited a month or two to re-gear to 4.88's and it wasn't that bad, the exhaust helped a bit and driving in town was just fine, but on the freeway it was like a 3.0 compared to a 3.4. Not terrible, just very noticeable. After I re-geared, everything was back to normal except driving up some of our Utah canyons and trying to maintain the speed limit would be a challenge. The S/C fixed that for me…
Old 12-15-2005, 07:24 AM
tarheelrunner's Avatar
I'm with HOJU, if you can get a good deal on the 35's (and they have decent tread) then pick them up and atleast try them out. If there's not enough power take them back off, atleast you'll already have tires out of the way when you regear!
Plus, most guys on here are running 285s w/3" of lift, so 285s on a truck with 8" of lift has got to look like it needs bigger tires....very soon!
Old 12-15-2005, 07:29 AM
shazaam's Avatar
go with 37's
Old 12-15-2005, 07:57 AM
Intrepid's Avatar
Until Lee met me I believe his "wheeling pics" were all on grass and I seem to recall one in a park with a picnic table and everything, hahahahaha. I am pretty sure I got the first pics of him actually wheeling, hahaha. No hate here, I still think Erik should speak for himself, but it was a good chance for a jab at Lee! Lee's truck isn't so clean anymore, we wheeled this past weekend and he pushed in his fender and front bumper and hammered his rear bumper, all without whimpering! I was impressed! Soon enough we will convert him to a non-bling wheeler! I actually loved to keep my truck nice and clean, I wheeled it for a year and it still looked brand new...then I started wheeling too much and too hard and it stopped looking so nice, then I gave up on it and bought an '85 4runner.
Old 12-15-2005, 08:38 AM
tc
tc's Avatar
Dude - you need bigger tires worse than anyone on here - they barely make it up past the bottom of the body in the back!
Old 12-15-2005, 11:33 AM
payyourtoll's Avatar
you are too tall for 33s imo.
go 35s or go home
Old 12-15-2005, 03:26 PM
2wheelBLACKOUT's Avatar
I say DO IT. It will be SICK!
Old 12-15-2005, 03:37 PM
4x4runnerGIrL's Avatar
DO IT!
i did.....
Old 12-15-2005, 04:13 PM
jeremys73's Avatar
Old 12-15-2005, 04:44 PM
waskillywabbit's Avatar
35s are soooooo last week...37s are where it is at!
