Shift Solenoid going bad?
Old 07-24-2012, 09:05 AM
x2468's Avatar
Has anyone ever had the shift solenoids in their auto trans start to go bad? My trans is shifting very hard when the fluid is cold, but when it's up to temp it's normal and smooth. i did some googling that seems to be pointing towards bad "shift solenoids"? My starter went out last week, so i'm familiar with the concept of solenoids slowly going bad until they fail. Would it be logical to assume that when the fluid is cold and thick, the weak solenoids are having a hard time doing their thing?
Old 07-24-2012, 09:35 AM
DRCOFFEE's Avatar
Try a stronger battery. The solenoids are electric so when the truck starts up on a weak battery the transmission cant shift as well until the alternator can supply a strong current and boost the battery. I went to an Optima Red Top that has higher CCAs than the stock battery did and the transmission's moring sickness went away.
It had the same effect on my Lexus IS300.
Old 07-24-2012, 09:10 PM
x2468's Avatar
Anyone?
Old 07-25-2012, 07:43 AM
mt_goat's Avatar
That's interesting, I would have thought the voltage with the engine (alt running) would over come a low battery but it is worth checking. Especially if both the battery and alternator are marginal.
Old 07-25-2012, 11:25 AM
DRCOFFEE's Avatar
The Alternator on these trucks is very weak at idle, so all of the accessories are reliant on the battery right after startup. I've considered the 140amp upgrade using a GM alt.
http://www.ultimateyota.com/index.ph...6&topic=9965.0
Old 07-25-2012, 04:24 PM
x2468's Avatar
Does it sound to you guys like this could even be a shift solenoid thing? or does it sound like more of a valve body thing? or Insert other option here???
chuckross1957
06-28-2019 10:19 PM
jgwerth
07-16-2015 03:23 PM
mengquis
07-13-2015 10:39 AM
crashburnoveride
07-10-2015 06:39 AM
Jnkml
07-06-2015 01:20 PM
Quick Reply: Shift Solenoid going bad?
