shake rattle and roll..what???
Old 10-21-2002, 09:00 AM
COTacoma's Avatar
Angry shake rattle and roll..what???
Newbie here, Hello to all!!
Heres the problem: My wife has a stock 99 Tacoma 4x4, it came with the small 28" tires, so i upgraded to 30" that were off my Jeep, ever since I added the larger tires we cant seem to get the thing to ride smooth(mainly at hiway speeds) like original. The first set wore terrible with lots of cupping, it was aligned 2 times in last 6 mos and tires balanced (as it feels like tires always unbalanced). This weekend put some new 30" and no change, crap!. So could it be the front struts/shocks need repalce, not handling the exta weight??? I go under truck and have wife turn wheel back and forth to see If anything loose, what i do notice is the whole rack and pinion does move back and forth a bit with each change in direction, is this normal??? all bolts were tight and I didnt see any broken mounts. Any ideas would be appriciated.
TIA
Old 10-21-2002, 11:13 AM
COTacoma's Avatar
Can someone tell me at least if the whole rack and pinion assembly moves at all on your truck when you move the wheels back and forth???
Thanks
Old 10-21-2002, 11:28 AM
Erc
Erc's Avatar
It's possible that they're not balancing your wheels right. Go here for great info on this http://www.gadgetonline.com/vibration.htm
Old 10-21-2002, 12:36 PM
CTB
CTB's Avatar
Bent rim?
Old 11-06-2004, 08:28 AM
mchombuilders's Avatar
It is normal for the rack to move somewhat, but look around this site for a while and you'll realize that tacoma r&p steering is problematic. liftthe front end and check each wheel for play. My pass side had 3/4" play and was eating tires. I bought a new rack for $100 from some spoiled 18 year old whose g'parents paid for an sas. problem solved.
gibbonsballer10
10-26-2023 07:13 AM
ashamsuddin
17
01-13-2023 03:17 AM
zytra
01-24-2019 03:16 PM
Corvoid
12-11-2015 11:21 AM
Flightguy
10-02-2015 05:34 PM
Quick Reply: shake rattle and roll..what???
