Seriously Toyota? My differential housing rusted out?
#41
My PU grew up in NH, I am now in Ca. This week I will have the frame patched for the 3rd time,and bed seams and spot welds are rusting some. Oh well. Here it is with por 15 in bed seams.
#43
Bad pumpkin
First things first don't blame a nation for the practice of a few slackers.Lets not forget we have quite a few in our history and plenty still living and many yet to be born It's good old boy arrogance to think that way.
This is some basic info from a black smith I spoke to the problem starts at the foundry in the smelting proses when either improper amounts of additives are used or all of the contaminates aren't removed this can cause rust to form inside the steel plate and make a weak spot and yes this even happens here in the good old USA.
I have been dealing with the same problem with 01 runner over the last four years it started out as a pin hole turned in to a 1/2 " hole so I pulled third member and axles plugged off the axel tubes cut out the cancer leaving a void that was 1 1/2" wide and almost 7 1/2" long welded on a 1/4"x2"x8" strap over the void left in my pumpkin cleaned out the pumpkin and reassembled worked great
PS. TOYOTA wont admit a thing untill someone gets hurt! Its not like a sticky gas peddle or a bad computer
#49
So last summer mine was leaking. Wire brushed and sanded the rust down to metal found 3 pinholes just below fill plug. Jb weld and undercarriage paint solved it. It started leaking again last month. Used a wizza' and man are parts THIN. Jb welded again. I'll check it out tomorrow and maybe put on another layer. Anyone in massachusetts that'll cut off the old cover and weld on a new fab'd one?
Pictures coming...
Pictures coming...
#50
After 1st coat of jb weld
Here's a PC once the 2 part was applied. After 20 min it started slowly making jb weld icicles off the bottom of cover. Had to kind of lift all the goop back in place. I used a lot!
#51
Sorry for the flood of posts but here are some more photos from my first attempt at solving the leak. It lasted 11 months to be exact! A couple hours and about $25 (including new gear oil).
https://www.flickr.com/photos/madcan...7642768785193/
#52
As far as I can tell this is a very limited problem.
I have been trying to buy a rusted out housing for quite a while to see if this would be a feasible way to repair these on a exchange basis.
Every one wants to sell me good ones
If I was closer I would love to repair this.
One has to blame the EPA for this wanting higher and higher fuel mileage weight gets cut where it can.
#54
I think New England killed it. The parts were thin because I wanted clean metal for repair. Funny thing is everything above the fill plug is solid. Second coat of epoxy went on this AM and the bonds look great.
Regency
20
01-03-2020 07:43 PM
