SCORE! Got a supercharger for $325!!
#42
Then get a wideband and OBD scanner and i should be good to go for that.
I just don't want to have to open the engine again for a long time so if the spring ARE a weak spot I want to get those changed out now. Anyone know for sure one way or the other?
#43
Yep, an egine oil cooler, already and a tranny cooler. I think i might pick that up then.
Where did you mount yours? that is something i was thinking about and could not come up with a good place for it except in front of the radiator but the tranny cooler is already there....
https://www.yotatech.com/forums/f160...5/index23.html
#44
Thanks for the link, lot of good info there, good to know that i am not even close to going overboard on cooling.
I read through a few pages, anything change since that thread? ever get your temps down?
Now i have lots of ideas to play with.
#45
check the bearing on the tensioner pulley. a friend of mine bought a supercharger for his 4runner that the seller stated needed to be rebuilt. he noticed that the tensioner pulley was almost frozen solid. he ended up with an operational s/c for $250 plus a new tensioner.
#47
Going to try to open it up tomorrow and see what it looks like inside then i will know what kind of deal i got. I found a rebuild kit for $75 if the nose is really all that needs to be done.
#48
Ok, so I am taking the Supercharger apart as i type and first off i am VERY happy with what i have seen so far. The oil was still perfectly clean and it looks mint inside.
I am trying to figure out how to take the nose bearing out, anyone know how to do it? I can't figure out what side i need to tap it out. From the pulley end? Or from the inside out?
Anyone know? Also, anyone know how to take the roots out? I don't think i am going to as everything looks so good i doubt there is anything wrong in there. Plus it spins SOOOO smooth.
So how do i get the bearing out?
#52
Ok, here is a build up thread for my truck, all future updates will go here:
https://www.yotatech.com/forums/f2/t.../#post50842922
LCE_Performance
10-01-2015 01:03 PM
anniesball
10
09-15-2015 05:41 PM
anniesball
09-09-2015 09:55 AM
2007, 34, 4runner, 5vzfe, bhp, cone, cover, fourrunner, m62, nose, pulley, rubbing, supercharged, supercharger, urd
