RS3000 or not?
Old 05-28-2009, 06:09 AM
cbrew325's Avatar
RS3000 or not?
I picked up a new to me 98 4Runner SR5 this last weekend and I am a little confused on the alarm\keyless entry. It has the standard RS3000 looking remotes, but I'm not positive its an RS3000. It doesn't have the typical center console mounted red security light that they normally have. I also tried following the programming instructions to disable automatic door locking and that doesn't seem to work. My remotes do seem to be functional as far as keyless entry goes. Did 3rd gen 4Runners ever come with something other than the RS3000? Theres a black box under the driver's seat, but I can't tell what model is without removing it. Any ideas? The missing light is what really has me confused.
Old 05-28-2009, 07:10 AM
cbrew325's Avatar
Just looked and it appears there is no piezo buzzer under the hood. Seems like I have some kind of partial RS3000 setup.
Old 05-28-2009, 07:12 AM
Staff
DeathCougar's Avatar
Do your remotes have the Toyota symbol, or say Toyota on them?
I would say just take out the 4 bolts and remove the drivers seat, and start tracing wires.
Old 05-28-2009, 07:29 AM
cbrew325's Avatar
Yep, normal looking RS3000 Toyota remotes. I did trace some of the wires. Everything looks correct coming from the module and heading up under the dash.
Old 05-28-2009, 06:22 PM
Shubey's Avatar
I think Toyota may have offered a keyless entry version instead of a security system on the RS3000.
Old 05-29-2009, 08:30 AM
sdsurfer's Avatar
post a pic of remote dude...
Old 05-29-2009, 08:49 AM
Ron Helmuth's Avatar
RS3200 also used in 3rd gens-but not stock to a 98.
Old 05-29-2009, 03:30 PM
cbrew325's Avatar
Okay, so the answer is not. I just pulled out a little black box that says Toyota VIP System. Model: KEYLESS ENTRY (08190-00930). It has 2 plugs on it. One is a small 2 pin plug and the other is a 14 pin. Definitely not an RS3000. As I said early, the remotes look just like RS3000 remotes, but maybe they are different. Anyone have an idea of how to change programming options on the keyless entry ECU? I'd like to turn off automatic door locks.
http://i42.tinypic.com/2e5ntk7.jpg
Old 05-29-2009, 08:05 PM
cbrew325's Avatar
I found the information I was looking for via the Supra community. Apparently 97/98 Supras came with this keyless entry only add-on.
http://94supraturbos.synthasite.com/...less-entry.php
jfrahm
02-18-2015 02:27 PM
Double Tap
07-25-2012 10:29 AM
superfliez
01-06-2008 07:43 PM
jharris2
05-27-2005 04:34 PM
midiwall
01-14-2004 07:39 PM
Quick Reply: RS3000 or not?
