rs3000 install help
Old 03-28-2005, 10:46 AM
NorCalVP's Avatar
rs3000 install help
Ok I've got most of the system hooked up, and removed the POS aftermarket alarm that the previous owner installed. After i removed the Aftermarket alarm, I made sure everything functioned as normal. Where i am having problems is i bought this used, and there is one clip that i have no idea where it goes... and 4 bare wired (no clip) I need to know where to splice them in.
I have the clip that plugs into the ignition, and the plug that plugs into the connector that comes from the door (blue one) but the one i don't know where it goes has three wires, and all are in a line. Blue with a yellow stripe, black with a white stripe, and yellow.
There are two wires by the ignition plug that are red and Green
There are also two wires that are between the blue (door) plug and the alarm ECU. They are also red and green...
Anyone know where these wires go???
Steve
Old 03-28-2005, 05:20 PM
Bob_98SR5's Avatar
steve,
i'm assuming you have the install manual, right? if not, i have it on my writeup at http://www.4runners.org/articles/rs3000. that should help you.
for the most part, the install of the rs3000 is plug and play. there were a few wires that needed to be tapped and in the install kit, they give you splices (which i think is the problem why so many rs3000 alarms are buggy).
in anycase, i would re-read the install manual and directly solder the wires where needed vs using splices.
on another note, why didnt you get in the commando 870 group buy?!?!? most of us were unsatisfied with the rs3000!
bob
Old 03-28-2005, 06:27 PM
SLC Punk's Avatar
He bought it used from me for a great price.
Steve,
The only harness that would be hard to find, is the one that plugs into the back of the fuse panel (upper right hand corner).
I didn't note the wires that need to be tapped, But the install manual that Bob has linked you to should work. If not, take some pics, and I will do the best I can to help.
-travis
Old 03-28-2005, 06:39 PM
NorCalVP's Avatar
Bob, Thanks that is just what I needed... There were just a few wires that needed to be spliced, and i wasn't sure what they did or where they went. That article is just what i needed.
Realistically I really didn't need the alarm features of the Rs3000, All i wanted really was keyless entry. (about to have my Second baby in 2 years...) and fumbling for keys can be a pain when you have just one, I can only imagine with two. I got it from SLCPunk for a great price, and it's just what i wanted...
Thanks for the help, Got it working great tonight.
Steve
BTW why is everyone so unhappy with the Rs3000?
Old 03-28-2005, 06:40 PM
NorCalVP's Avatar
Thanks Travis, I just read Bob's article, and it had just what i needed in it. I Soldered the joints instead of wiretaps, so hopefully i won't have any bugs...
Thanks again it's working great!
Steve
Old 03-28-2005, 06:47 PM
SLC Punk's Avatar
Steve
Whew! That's good to hear. I didn't note the wires that were spliced. Glad you got it wired up ok!
Did you install the new Pezo?
Old 03-28-2005, 06:49 PM
SLC Punk's Avatar
My only complaint was the remote range. Its only 15 ft or so.
Old 03-28-2005, 08:06 PM
Bob_98SR5's Avatar
steve,
over the years i've noted the following:
- spotty reliability (probably due to splices)
- range (as travis mentioned)
- malfunctioning or failing piezos (over a long period of time, but should last longer than it does)
now dont think that EVERYONE has these problems. these are just some of the probs ive experienced as well as some others
bob
Old 03-28-2005, 08:15 PM
NorCalVP's Avatar
Originally Posted by Bob_98SR5
steve,
bob
That's good to hear bob.
I soldered all of my connections, so that shouldn't be a problem. I hate those damn wiretaps anyways...
Range shouldn't be that big of a consern. It's parked in the garage at night. and really i don't need a ton of range.
The piezo I disabled anyway. I don't like the sound of the chirp. I just use visual conformation when the lights blink.
Sounds like I'll hopefully be pretty happy with this.
Steve
nvdesertrunner
05-11-2020 08:18 PM
wwjr
09-07-2015 09:27 AM
punks_is_4x4
08-21-2015 01:35 PM
Esibnitsud
07-30-2015 08:19 PM
Quick Reply: rs3000 install help
