Rough Idle after plug change
Old 11-15-2004, 09:19 PM
Sludge's Avatar
I changed out the plugs - wires - cap and rotor today on my 92 runner(3vze). The idle seems to be rough more so then b4 the change and the engine jumps slightly. The wires are on correctly. For some reason it just doesn't seem right to me. Any trouble shooting tips would be great since right now since i have been beating my brain for hours now.
Old 11-16-2004, 06:57 AM
Waterboy's Avatar
What brand of stuff did you use? When I first got my truck I stuck bosch platinium 4's in it and it ran crappy until I changed them out for NGK's.
Old 11-16-2004, 07:20 AM
jht3's Avatar
check your plug wires again. i goofed and hooked up 2 wires wrong when i replaced everything. ran like ˟˟˟˟ until i took a deep breath and traced my wires.
double, triple, quadruple check your install. something may not be screwed down, or plugged in all the way. check the gap on the plugs.
Old 11-16-2004, 08:54 AM
Cebby's Avatar
Check the gap. Also, how hard were the wires to get off? They may have gotten damaged from yanking on them. Use OEM Toy stuff.
Old 11-16-2004, 10:11 AM
Bob_98SR5's Avatar
i had a slight pulsing after i changed my plugs about a year ago. it was b/c of the gap in one of the plugs. try checking them all and see if theyre all gapped correctly.
bob
Old 11-16-2004, 10:13 AM
ugadawg95's Avatar
yes check the gap...i had the same problem when I changed the plugs. Of course it was the last plug I checked :0
Old 11-16-2004, 10:35 AM
Steve 1stgen's Avatar
I have a 1988 4Runner where the same thing happened after a proper plug change. It turned out, the airhose that connects the Airfilter to the manefolder got cracked as I was putting it back on. If there is not a sealed air flow, the engine does run proper. I don't know if they changed this for a 2nd gen 4Runner.
Check your air hoses and I hope this helps
Old 11-16-2004, 04:17 PM
Mad Chemist's Avatar
Could be a bad plug. Buy one more new plug (or use one of the old ones) and swap them out one at a time.
Old 11-16-2004, 05:38 PM
Sludge's Avatar
Thanks for the info guys. All the parts i got where OEM ($87 for plug wires )The problem was a cracked throttle body hose. When i went to pull the hose off again to check the plug the hose crumbled at the TB. I got a replacement hose from the junkyard till i order a new from the dealer. All seems to be fine now.
smthwsn357
05-01-2024 07:28 AM
sandyota
02-04-2021 11:16 AM
icentropy
09-16-2020 02:47 PM
09-04-2015 09:27 AM
smiley52
07-11-2015 05:16 AM
Quick Reply: Rough Idle after plug change
