Old 04-15-2016, 09:09 AM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Toyota 4Runner Engine Guides
Print Wikipost
Replacing valve cover gasket
Old 11-23-2009, 10:16 PM
MunkeyTX's Avatar
Originally Posted by logsurfer
1. Where is the load proportioning valve on my rig(97, 3.4, 2wd)? A pic would be helpful too.
We don't have one, only the Tacomas.
2. It looked like the hawk pads had shims attached to it already, am i right?
Looks like it from the photo
...There is also a little piece of metal attached to the brake pad that I broke off, i didn't bother to put it back on. I'm guessing thats the metal that rubs to the rotor when there is no pad left to tell you that you need to replace your pads.
Was it a small 90* bent piece of metal held on by a screw or rivet at the end of the pad? If so, then thats exactly what it was.
THANK YOU for shedding some light on the loose valve cover bolts issue. I had a leak worse than yours, and mine were EXTREMELY loose. Saved me some time and money!
Old 11-23-2009, 10:59 PM
iceman601's Avatar
Replacing the valve cover gasket isn't as hard as it looks but it does take some time to get to it. The passenger side is the easiest but the driver side will take some time to fight the wiring harnesses and other stuff that is in the way.
Heres a couple of pics from my project:
https://www.yotatech.com/forums/f2/5...beware-149594/
Old 11-23-2009, 11:10 PM
b0n3mast3r's Avatar
i replace my valve cover gasket while i was replacing one of my dead injector
Old 12-14-2009, 12:00 PM
logsurfer's Avatar
Update: parts quote
so i've decided to replace my valve cover gasket bcause it's still leaking in the back (near the firewall). I leaks really bad especially after a long drive.
Here is the quote for the parts:
(2) valve cover gaskets = $44.30
(6) Spark plug gaskets = $17.88
(16) "crush" washer = $14.08
(2) air intake plenum gaskets = $23.36
this is with a 15% discount.
stay tuned folks, i will be tackling this job soon!
Old 12-14-2009, 01:50 PM
  #25
akaphilly's Avatar
nice, i plan on doing this soon so take some pics! how about part numbers for everything?
Old 12-14-2009, 08:02 PM
  #26
logsurfer's Avatar
The Culprits
all leaks are coming from the head of the rotating part..
I think i need to buy the gaskets for those too?
these are the part nos i have so far:
(2) valve cover gaskets/11213-2020/$44.30
(6) sprkg plug seals/11193-70010/$17.88
(16) crush washers/90210-05007/$14.08
(2) air intake plenum gasket/17176-62040/$23.26
Attached Thumbnails Replacing valve cover gasket-under-drivers-side.jpg   Replacing valve cover gasket-under-passenger-side.jpg   Replacing valve cover gasket-culprits.jpg
Old 12-15-2009, 09:15 AM
  #27
logsurfer's Avatar
so it looks like i need to replace the oil seals in the rear. do i need any special tool for this?
Old 12-15-2009, 08:18 PM
  #28
FlzRider's Avatar
I changed the VCG on my 4runner this past summer to cure the oil leak coming from the back of the valve cover, primarily the passenger side, similar to yours. Well, it is still leaking, so this coming weekend I will replace them again, but this time I bought the Toyota brand FIPG (form in place gasket) and will also be replacing the half moons and some other parts I didn't change last time. Hopefully it cures the problem.
Old 01-19-2010, 03:35 PM
  #29
logsurfer's Avatar
Update: Work in progress
So I'm in the process of replacing my valve cover gaskets but there is a roadblock.
I can't get the 2 coolant hoses off the throttle body. I've already removed the clamps
but i really cant get it off,and I've read somewhere here to undo the (4) screws but can't get them to turn and I'm afraid i might strip it.
I know a lot of guys have dealt with this.. Can you give me some advise on how to remove these suckers.
P.s. dnt worry i'm taking pictures
Old 01-20-2010, 10:43 AM
  #30
stir_fry_boy's Avatar
Sometimes it is easy to just twist the hose to break it loose off the nipple and then it should pull right off. Make sure you remove the clamp far enough down because in this pic they are still on tight. If you use a pair of pliars or something you may put a hole in the hose.
Old 01-20-2010, 12:46 PM
  #31
logsurfer's Avatar
stir_fry,
Here is the pic of where my leak is coming from
oil leaks out below that circular rubber cap.
how do i remove that circular rubber thing?
and a picture of my 110k engine
Old 01-20-2010, 02:26 PM
  #32
You don't remove the circular cap. That stays there. There should be some silacone left over in the right angle where the cam goes over the head. You need to remove the silacone only. After you get it clean, you will put some FIPG or HondaBond where the right angle is. You will also put some where the upside down semi-circular caps go where the other cam (toward the outside of the engine) is. You will need to scrape off all the old silacone. I did it with my fingernail, you can carefully use a razor blade but don't use a screwdriver or you can scratch the head. Don't remove the semi-circular caps. So that is 4 total places where you need to put silacone on each END of each head.
They usually leak there because of the right angle. It won't be a problem with a little bit of silacone to seal the gap.
Once you put on the silacone, you only have about 2 minutes to get the cover back on and bolted down at least somewhat. I used an inch-pound wrench to 53 in-lbs. I alternated tightening bolts to get the cover to go down as flat as possible. 53 in-lbs is the FSM torque spec. Let me see if I can circle where you need to put the FIPG.
Here you go:
See the RED circles?
Here is the right angle I am talking about (red circles indicate where you should put the FIPG):
Right side circle is UNDER the silver bar.
BTW, what is that silver bar? I don't recognize it.
Old 01-20-2010, 02:53 PM
  #33
logsurfer's Avatar
gotcha stir fry! it makes sense now, the leak is coming from that right angle and goes down to the rubber circular cap. at first glance you would think that the oil is coming below the housing cap. btw, the silver bar on the left is a ground wire, it grounds the engine into the body of the t4r. If you're asking about the bar on the right, its the arm of my mirror tool.
Thank you very much!
Old 01-20-2010, 05:05 PM
  #34
No prob! You need to make sure all the silicone comes off of the flat surface on the head (i.e. anywhere where the valve cover meets the head) especially in the right angles where you are going to put some new FIPG. In other words, the surfaces that touch any part of the valve cover gasket must be free of debris, oil and silicone or else when you put the new FIPG on, it will not seal and obviously leak. Then you put the FIPG on where I showed you, then the valve cover (with the valve cover gasket installed into the valve cover). If the valve cover gasket doesn't stay good into the groove, you can use some Vaseline to hold it in place. I didn't have any trouble with mine staying put without Vaseline. If the valve cover gasket folds over itself when you put it on, it will leak like crazy.
HA! I didn't know what your mirror was when I first looked at your pic.
Did you replace your spark plug tube seals? Those are a royal PITA! I had to ruin my old ones in order to get them out.
Old 01-20-2010, 08:53 PM
  #35
logsurfer's Avatar
Yes, I did. I went to the stealership with my pasenger side valve cover and a tech showed me how. he removed all three in less than 15 seconds
Old 01-21-2010, 05:24 AM
  #36
How did he do it? It took me about 10 minutes to remove all 3. I used a hammer, a small flat head screwdriver and a pair of pliars.
Old 01-21-2010, 10:48 AM
  #37
Ken
Ken's Avatar
+1 same here. Did the tech have an angled tool to tilt out the old ones?
Old 01-21-2010, 07:09 PM
  #38
logsurfer's Avatar
Sorry guys for the late reply, it's been a long day
He removed the spark plug seals using a (-) screw driver and a rubber mallet:
angle the screw driver towards the hole and give it some love taps with a rubber mallet.
your old seals should look like this after removal:
Update:
While I was trying to clean the mating surfaces, a piece of plastic fell into this crevice and I can't get it out
Old 01-21-2010, 08:30 PM
  #39
Ken
Ken's Avatar
Ah ok. I was trying to avoid damaging the valve cover, so was tearing at the inside of the seal.
Try a wet/dry vac to suck out the plastic piece?
Old 01-22-2010, 07:13 AM
  #40
That is exactly how I removed my spark plug tube seals. Did you try some tweezers to get that plastic out?
Quick Reply: Replacing valve cover gasket
