Replace fuel pump or sending unit? 96 runner
Old 08-04-2011, 06:18 PM
punkelberg's Avatar
I have a 96 3.4L with a TRD SC on it, 2.1 pulley, 4:56 gears and 31" Mudders...
I filled it up with gas last night, drove 30 miles and I'm just above 1/2 tank....until I exit the freeway where my gas gauge drops to 1/4 tank while I'm at the light.
I'm guessing it's the sending unit, but my question is with regards to replacing the fuel pump as well. The PO kept EVERY receipt he ever got and looking through I saw someone had installed an "in tank fuel pump" when the installed the SC. Do I need to buy a aftermarket fuel pump or will OEM do?
Should I bother with the fuel pump or just replace the sending unit.
I searched the forums and found several referances to the sending unit issue, none with regards to the SC.
Thanks in advance!
Old 08-04-2011, 07:21 PM
smokey0066's Avatar
I would open it up and see if its after market or stock so you know what you need to order.
Old 08-04-2011, 08:36 PM
punkelberg's Avatar
It's my daily driver, so I'm trying to limit down-time and avoid doing the work 2x...I'm just wondering if I buy an OEM pump/sender will it be adequate? Truck also has a URD Additional Injector Controller / Timing Calibrator unit.
Old 08-05-2011, 04:03 PM
cpizzle42's Avatar
The pump is probably the Walbro 190 that comes with the URD kit. Why would you need to replace the pump? It is working fine right? Do you have a AFR gauge with that 2.1" pulley?
Old 08-06-2011, 06:29 AM
sdsurfer's Avatar
96 runner, ltd 4x4 same thing since owned. 229k now 295k I dont worry about it. the gas light is still accurate as heck and I get my tank down to 17.6 empty...once the gas light turns on and stays on when performing right turns, go get gas! im ghetto though so whatever
Old 08-06-2011, 11:06 AM
cpizzle42's Avatar
..This is not want you want to do. You will burn up your pump.
voiddweller
19
05-02-2016 09:10 PM
kazuya2416
06-27-2015 12:24 PM
Peteyg39@hotmail.com
06-26-2015 08:15 AM
Mutinebullfrog
06-18-2015 01:36 PM
Dennis140
06-17-2015 10:37 AM
Quick Reply: Replace fuel pump or sending unit? 96 runner
