removing 3.4 engine to replace freeze plugs - what else should I do while its out?
Old 02-11-2012, 09:56 AM
43jeeper's Avatar
Title pretty much says it all. Im removing the 5vz out of my 2000 4runner and replacing all 11 freeze plugs and the timing belt/water pump. Anything else I should do while it out? Im no expert on these engines and this is not my DD, so time isnt a factor.
Anything cheap in parts cost that is a bear to do with the engine back in?
Or even things that are simple to check while the engine is out?
Old 02-11-2012, 10:13 AM
93toyrunner2's Avatar
Rear main seal - use OEM only!
Old 02-11-2012, 11:06 AM
rworegon's Avatar
Just curious....why go after all 11 freeze plugs?
Replace everything in the kit below along with a new crank bolt, radiator hoses, and other hard to reach hoses coolant vacuum hoses from your local dealer. Also, a new knock sensor wire...yours will be cooked from the heat underneath the lower plenum.
http://www.ebay.com/itm/Toyota-TIMIN...item2a144a37e8
https://www.yotatech.com/forums/f2/n...review-247545/
Old 02-11-2012, 12:45 PM
rworegon's Avatar
Replace the starter contacts and plunger since the starter will be accessible?
Old 02-12-2012, 07:12 AM
aowRS's Avatar
+1
Andreas
voiddweller
19
05-02-2016 09:10 PM
DacodaYota
09-02-2015 02:13 PM
Edionne13
06-21-2015 11:37 PM
HBoss
12-20-2004 08:45 AM
peterbilt
07-18-2002 05:16 AM
Quick Reply: removing 3.4 engine to replace freeze plugs - what else should I do while its out?
