Rear wheel bearings?? - 4runner
Old 05-21-2010, 01:11 PM
Yota Yeti's Avatar
- 97 4runner with 99 rear axle housing and elocker -
I noticed a rear end popping noise when my frame flexes, ie going slow through a pot hole at 1-2 mph. So I started checking around my rig and when I grab the rear wheel and start pushing on it just enough to get the cab to rock, i feel a little thud like metal on metal. I think it means my rear wheel bearing is bad. Does this sound right? I can get the noise when I rock the rig from both sides. Both bearings then?
I also notice the same pop only louder when making a right turn after a stop.
Old 05-21-2010, 02:29 PM
michalik_piotr's Avatar
you will notice a bearing noise while you drive...it will increase with speed.
Old 05-21-2010, 02:43 PM
Yota Yeti's Avatar
so before the swap I had bad axle bearings. I found a good deal on axle and e locker so i did the swap and got rid of the bad axel bearings. The whine that was present is now gone.
TNRunner88
07-01-2015 08:00 PM
Mr.Black
06-21-2015 10:17 AM
AustinTaco
06-21-2015 09:54 AM
HBoss
15
06-20-2002 05:28 PM
Quick Reply: Rear wheel bearings?? - 4runner
