Rear diff whining
Old 05-27-2010, 02:34 PM
jdm_95_ls's Avatar
Rear diff whining
i just rebuilt the differential case with a new pinion and ring and after i put it all back together i drove it around for a bit and everything i let go of the gas the whine starts to happen, also it has a rear diff lock. the light happens to be on all the time too, the abs light has been on too since i've changed it. i was wondering if anyone on here can give me tips i'm stumped, this is my first 4x4 car, i've worked on hondas and mitsubishis before so i'm not new to this stuff.
Old 05-27-2010, 02:39 PM
98.T4R's Avatar
i had a truck do the same thing and it was due to worn slip yolk gears
Old 05-27-2010, 02:42 PM
Sponsor
Tofer's Avatar
how did you "rebuild the differential case"... did you set backlash, and pinion depth? because its whining i am guessing not...
gears need to be set by someone who has the tools to do it...
Old 05-27-2010, 03:12 PM
82blueyota's Avatar
go to gearinstalls.com and check to see if you set the gears up like he does.
Old 05-27-2010, 03:45 PM
brian2sun's Avatar
Setting up gears can be one of the most difficult things an auto mechanic has to do. You jumped in head 1st so I'll give you that! Did you follow the FSM or just wing it? It sounds like you need to reboot and start over.
Old 05-27-2010, 03:55 PM
Sponsor
Tofer's Avatar
also.. when you installed the new gears in the rear, did you use the same ratio as the front?
Old 05-27-2010, 09:05 PM
jdm_95_ls's Avatar
i'm sure it's the same ratio it's a 2000 4runner 6cylinder limited with diff lock, it was 4.10 i believe. but is this the reason why the diff lock light is on also? and the abs light is also on.
Old 05-29-2010, 03:20 PM
jdm_95_ls's Avatar
well i just got another one from the junkyard put on, i guess it was a 4.30. but the abs light and diff light is still on, also the car jerks when you take off and the tires screeches. can anyone put any input in what is wrong. also how do you tell if the diff elocker is broken?
Old 05-29-2010, 08:49 PM
jdm_95_ls's Avatar
bump want to get this fixed
Old 05-29-2010, 09:45 PM
houston64's Avatar
if it takes off and screethces like that im guessing your in 4 wheel because if the ratios are different in the axles it will cause it to pull and jerk.
Old 05-31-2010, 03:35 PM
jdm_95_ls's Avatar
i think it also happens when it's only on 2 wheels too, i'm not sure it's my friends dads car and i'm suppose to be fixing it.
Old 05-31-2010, 03:40 PM
toyota4x4907's Avatar
it will happen in 2wd also because you have ADD, therefore the front drive-train is spinning regardless of if its in 2 or 4wd.
polo451
13
11-20-2016 07:49 PM
jerusry
10-19-2015 05:28 PM
Daneums
08-20-2015 05:36 AM
jaretstuff
08-04-2015 02:08 PM
scottyg486
07-19-2015 05:34 PM
Quick Reply: Rear diff whining
