rear diff is making a whine noise
Old 09-17-2005, 02:45 PM
Foch's Avatar
My 98 4Runner's rear end........I'm getting a whine from the rear diff that seams to be getting progressivly louder with time. It's got 116,000 miles. I've been using Mobil 1 75W-90 since 50K, changed at 100K.
Would a heavier gear oil help? Is the rear diff doomed at this point?
Thanks in advance.
98 4Runner
4 cyl, 5sp, 265/70-16 tire package
Old 09-17-2005, 02:55 PM
waskillywabbit's Avatar
rear driveshaft u-joint(s)
Old 09-28-2005, 01:34 PM
6lug's Avatar
"My rear end is making a noise...help. "
whats your diet like?
Old 09-28-2005, 01:38 PM
shazaam's Avatar
Old 09-28-2005, 01:40 PM
shazaam's Avatar
have you taken the truck off road or gotten water in to the rear diff? change out the diff fluid and see if that helps
Old 09-28-2005, 05:00 PM
Ironmike4x4's Avatar
At what speeds does the whine occur? Does it happen under a load or when deccelerating? I'm thinking what Wabbit is saying if the noise is constant and not the latter. If it's during decceleration or acceleration I would see about having the backlash checked.
edit: Forgot to mention... try to isolate the noise. For example, rule out tire noise by raising the rear end up and then CAREFULLY put it in gear and get up to speed. If the noise is still present then you know tires aren't the cause. Also you may want to go on a downhill ride in a secluded area, CAREFULLY switch into neutral and shut the engine off. You will no longer have power steering or a good set of brakes so use caution. If the noise is still present then you've ruled out a drive shaft problem.
Old 09-28-2005, 05:12 PM
jimbo74's Avatar
lay off the late nite del taco runs
Old 09-28-2005, 05:21 PM
bob200587's Avatar
(insert anus joke)
Old 09-28-2005, 05:27 PM
Good question, stupid answers
To think that some one will be searching this and find stupid and irrelevant answers.
Old 10-14-2005, 11:48 AM
leiniesred's Avatar
Noise goes away when there is no load on the diff.? louder under more load?
Loose pinion bearings.
They wear out a little. the shaft is allows to move a little. the gears mesh a little different and it whines.
You can rebuild the entire she-bang, but I would drive it until it howls.
Use the time to find a good used diff and/or consider this a reason to re-gear for bigger tires.
mskalmus
05-28-2017 07:51 AM
MTLroadierunner
07-15-2015 12:58 PM
icentropy
07-11-2015 07:21 AM
Gamble_STi
07-07-2015 07:54 PM
MTLroadierunner
07-06-2015 12:17 PM
Quick Reply: rear diff is making a whine noise
