Rear ABS sensor Good or Bad after trashed rear bearing
Old 09-14-2010, 09:25 AM
98Yotabeast's Avatar
I recently had a trashed rear bearing on my 98 runner and there were chunks of metal and oil on the abs sensor.
I am wondering since it is a magnetic sensor, should I replace it or just try to clean it up with some electrical cleaner?
I am thinking about installing the axel back in and if the abs light is blinking then I will swap out the sensor since it is only one bolt to remove it.
Any help is much appreciated!
Old 09-14-2010, 12:31 PM
hross14's Avatar
Just clean it--had the same issue but mine had metal shavings from fabbing....
AustinTaco
08-22-2022 10:45 AM
voiddweller
19
05-02-2016 09:10 PM
cchinny
06-25-2015 08:11 PM
XtremeOff-Road
16
06-27-2002 07:32 PM
sassy4runnerchic
18
06-06-2002 02:21 PM
Quick Reply: Rear ABS sensor Good or Bad after trashed rear bearing
