Last edit by: IB Advertising
Browse all: Toyota 4Runner Electrical Guides
- Toyota 4Runner 1996-2002: How to Replace Oxygen (O2) Sensor
Step by step instructions for do-it-yourself repairs.
Q replacing O2 sensors. (Replace both?)
So I pulled a P0133 today on the way home from work. Had the code cleared and it hasn't reappeared since. All my reading leads me to believe that the O2 sensor needs to be replaced. I figure I'll go ahead and clean the MAF while I'm at it.
I haven't been able to confirm it, but my reading leads me to believe that there are two O2 sensors. Is this true? If I'm to replace one, should I go ahead and replace both?
I remember reading somewhere that one of them is a lot more likely to go out than the other, and that you might as well just replace the one that goes out. It would be a while till the other one, less susceptable to fail, would go out. Not sure how true this is, but lets see if somebody can confirm it.
The one behind the cat is there to be sure that the cat is doing it's job. It has no bearing on how the engine is running.
Did you happen to search on "P0133". There is a ton of discussion about this.
Anyway... The P0133 is:
P0133 O2 Sensor Circuit Slow Response (Bank 1 Sensor 1)
This means that the ECU doesn't think that the FRONT O2 sensor is providing data in a timely manor. That's a sign of it getting old.There is NO reason to replace both sensors. Even from a "preventative maintenance" point of view. The rear sensor will run you about $90, the front one for your year is about $130 (I think). Replace the rear one when the ECU complains about it, nothing will happen to the driveability of the truck when it goes, whereas the front one being flaky will turn into poor mileage and/or power.
Thanks for clearing that up for me, guys.
And yes, Mark, I read every single post in every single thread last night that contained "P0133" I just got the feeling that there was more than one, and was curious if it was a good idea, preventative-maintenance-wise to replace both at the same time.
I can pickup an Denso O2 sensor from a local auto parts shop for $141. Or order one from Gadget (urdparts.com) for $8X. I think I'll hold out a while longer and see if I get the check-engine light again soon.
I need to purchase some minor parts from Toyota anyway. Need to replace the clutch spring bushing-thingy (squeeeeeking) and the gasget above the gear box so it shifts a bit easier.
If it is a 1998 then both sensors should be an O2 sensor and both should be about $90 from URD.
Only replace the front sensor as Mark suggested.
Originally Posted by MTL_4runner
Mark is right on except....
T
Location: Far western Kentucky (transplanted from central PA)
It appears from what I've seen and read that the front O2 sensor takes the brunt of failures. I had the one ahead of the cat replaced and figured I'll wait for the one behind to go in lieu of doing both, especially since the later doesn't impact driveability like the 1st one might (my truck actually got better mileage with the bad sensor!). Matter of choice, I suppose.
...the 1st one might (my truck actually got better mileage with the bad sensor!).
"Driveavbility" doesn't just mean "good mileage". Acceleration, torque, engine life... there's a lot of stuff in there.
It's in hotter gasses, and the ECU is looking for a lot more to go out of kilter than the rear.
TURBOrunnerNM
07-22-2015 11:01 AM
rushw
07-18-2015 01:46 PM
