Post your axle code!
Old 11-19-2004, 11:53 AM
  #41
terryjmatthew's Avatar
VZN185L-GKPGKA
A03A/A340F
Best I can tell, That means 4.10 2-pinion right?
Old 11-19-2004, 12:16 PM
  #42
r854rnr's Avatar
Originally Posted by servo_fan
Which table were you looking at? There are several out there and most of them are really meant for 1st and 2nd gen 4Runners, (and older trucks). I believe for 3rd gen 4Runners the following link is the most accurate, (again this link is also on the yotatech FAQ page). http://www.vibratesoftware.com/html_...ear_Ratios.htm
It goes by model code not by the axle code. If the door sticker says yours came with 225/75 from the factory then you are most likely running 3.909 gears and the 265s were added after it left the factory, (unless it was regeared at that time as well).
Thanks for that link. That made things a little less broad. However, I have 265s of there now, w/ stock 16" rims. The spare is the same size. Is there any way to tell what came on my specific truck?
Thanks for th help.
Old 11-19-2004, 12:39 PM
  #43
servo_fan's Avatar
Thanks for th help.
It may be best to use that link and check your gearing based on your model number. If the door jamb sticker says 225/75 then I would think that's how Toyota built it and it probably has 3.909 gears. The 265/70 tires were probably added sometime after final assembly.
Old 11-19-2004, 01:08 PM
  #44
r854rnr's Avatar
Based on my model number, there are 3 possibilities. 4.10, 3.909 and 4.30. I'm guessing 3.9 is me, but I'm hoping 4.10 or 4.30 is it! I guess i'll have to get off my but and go do it the spin test way.
Thanks for the help though.
Old 11-19-2004, 01:34 PM
  #45
servo_fan's Avatar
You're welcome. By the way, we can conclusively say the only way you have 4.30 gears is if yours came with the rear locker.
Old 11-19-2004, 08:34 PM
  #46
Schuey2002's Avatar
Is your Tacoma an auto or manual?
It has the stock A340F automatic tranny in it..
Old 11-19-2004, 08:46 PM
  #47
corvettelvr73's Avatar
G144 = 4.88 auto, V6, 4x4, 31" stock
Old 11-21-2004, 06:49 AM
  #48
cimahar's Avatar
1995 $runner SR5 V6 5 Speed G254 and 31x10.50x15 BFG M/T
Old 11-21-2004, 09:00 AM
  #49
boraxman's Avatar
My '96 Taco (B03A) has 3.4, manual, and came stock w/ 31" tires. I believe it is a 4.10 open rear.
Old 11-21-2004, 05:17 PM
  #50
Mossback74's Avatar
Acording to the last link I've got 4.10
Old 04-14-2005, 07:32 AM
  #51
Denk's Avatar
Way old thread resurrection...
Axel code G252 ==> 8", 4.56 gears, 2 pinion.
According to offroad.com and visual confirmation on my diff...I have 4 pinion. Difference btwn 2 and 4 pinion is the # of fins on the housing. 2 pinion = 3 fins...4 pinion = 4 fins. So my door jamb plate is labeled incorrectly. Anyone else have this issue?
Is either 2 or 4 pinion better or worse than the other?
Old 04-14-2005, 08:34 PM
  #52
dragon564's Avatar
G145 for the J spec
Old 04-14-2005, 09:12 PM
  #53
Crux's Avatar
A04A
I've got an e-locker, so I assume this means I have 4.30...
Old 04-15-2005, 03:30 PM
  #54
KZN185W's Avatar
Denk,
4 pinion is better/stronger than the 2 pinion.
Maybe your rear axle was replaced?
Cheers!
Old 04-16-2005, 09:20 PM
  #55
Denk's Avatar
Don't think it was replaced. The previous original owner kept immaculate service records and there was nothing about it. I read somewhere that the door jamb plates were commonly misprinted. But its good to know about it at least.
Old 04-16-2005, 09:44 PM
  #56
93YODER's Avatar
B04B,
31s stock
4.56
4 pinion
3.0 v6
a few months back I was very happy to find out I have 4.56s in there...
Old 11-27-2005, 08:12 AM
  #57
Sequoia'd's Avatar
'91 4Runner 4WD, G254, 31", v6 3.0, Auto trans A340H, Made in Japan.
So these are 4.56's right?
Old 11-27-2005, 08:09 PM
  #58
Ric
Banned - User requested
Ric's Avatar
Crux,
mine says A04A also, but, according to this site http://www.brian894x4.com/Gearratiosanddiffs.html we have 4:56
but this other site http://www.off-road.com/toyota/tech/other/4_axles.html says with the VIN starting with JT i have 3:556
im more lost now than before
Old 11-27-2005, 08:50 PM
  #59
CraZyRunner's Avatar
g144 4.88 all the way!
Old 11-28-2005, 04:27 AM
  #60
pat161's Avatar
2000 4Runner 2.7 5 speed 4wd
A05A = 4.556 2 pinion open
Quick Reply: Post your axle code!
