plug n play hid kit only works on hi-beam?
Old 07-26-2011, 05:50 PM
99 sas runner's Avatar
first off i know that i shouldn't be using hid's in the stock headlight, but it rarely sees the road.. with that aside, my friend gave me a set of plug-n-play hids and they only work on hi beam (no hid) i plugged them into a friends chevy headlight plug and they kicked on no problem.. what do i need to do? someone said something about toyota wires they're headlights different? any help is appreciated!
the car is my 99 4runner.
Old 07-26-2011, 08:09 PM
rideexileex's Avatar
Most likely the 3 wires in the relay harness need to switched around. Idk off the top of my head how the chevy's work, but the toyotas used switched grounds for the headlights. Either probe around with a meter or do a little guess and check
Old 07-27-2011, 12:04 AM
relay harness? im not good with electrical
Old 07-27-2011, 03:13 AM
xxxtreme22r's Avatar
x2 it's a switched ground versus switched power issue. You will most likely have to build yourself an upgrade headlight harness. You might be able to buy one though.
http://www.4crawler.com/4x4/CheapTri...s.shtml#SPtoSG
Also is it a bi-xenon kit? Because if it's not even after you get the wiring correct your gonna only have low and not high.
Old 07-29-2011, 12:56 AM
idk what kit it is i cant believe toyota has switched ground not power.. i learn somethin new everyday.. i really wanna get these workin
Scotttekoch
23
11-01-2021 12:41 PM
voiddweller
19
05-02-2016 09:10 PM
gog1968
06-22-2015 05:55 AM
streetuner15
06-18-2015 10:59 PM
LSUMatt1514
07-09-2002 03:26 PM
Quick Reply: plug n play hid kit only works on hi-beam?
