Please help URD FTC wire color question.
Old 09-27-2006, 11:13 PM
Fingers's Avatar
I have a 1997 Toyota HILUX SURF (4runner Limited), automatic transmision. Everything on the URD FTC connection diagram matched with one exception. The wire located on Plug B Pin 8 is solid red on my truck. The instructions identify this as the MAF sensor wire but say it should be Red w/white stripe. There is a red w/white stripe wire in Plug B, Pin 18. Anyone know which I should connect the Green w/yellow stripe and the Violet wires on the FTC to?
Perhaps someone knows how I can id the MAF sensor wire from another location.
Thank you for your help, I am stuck until I can get the answer.
Old 10-01-2006, 12:40 PM
Tragic Drive's Avatar
You can call Split second and ask specifics ask for Mark Amarandos (949) 863-1359.
coryc85
09-09-2015 06:24 AM
09-04-2015 09:27 AM
Gevo
07-29-2015 11:15 AM
88yodabasket
07-13-2015 01:32 PM
Johntom240
7
07-13-2015 12:18 AM
Quick Reply: Please help URD FTC wire color question.
