Paddle shift 4runner project
Old 12-08-2011, 09:04 AM
  #81
yotasavg's Avatar
Originally Posted by Clownmeat
It's not a kickdown cable, it's a throttle pressure cable. If you disconnect it the shifts would slip even more until you smoked the trans. You have to pull it out all the way and lock it down. This makes the trans think you have the throttle pedal mashed to the floor so it raises the line pressure accordingly.
AHA! Glad I asked so I now see where you have it locked down in the picture. So with it locked down I will experience a sharper shift, as if I were at WOT. And the reason it makes no difference at WOT, is because it's already sharp with the normally high line pressure WOT?
Old 12-08-2011, 09:06 AM
  #82
Texas_Ace's Avatar
Yep, exactly.
My valve body mod I just had done makes the shifts even sharper, I really like it but want them sharper then they are right now so the shop is going to work it over a little more to sharpen it up a little more. Feels SO much nicer with the positive shifts even just driving around.
Old 12-08-2011, 09:10 AM
  #83
yotasavg's Avatar
Awesome thanks Clown and TA! (unhijack)
back to 3rd gen awesomeness...
Old 12-08-2011, 03:55 PM
  #84
Clownmeat's Avatar
Had some time today to get the left paddle in and built a harness for both and wired into the clock spring.
Old 12-08-2011, 03:56 PM
  #85
Clownmeat's Avatar
Stupid youtube.
Old 12-08-2011, 03:58 PM
  #86
Texas_Ace's Avatar
Looks good! A tip for making that hole you cut look a little better is to use a soldering iron to melt the edges. Done right it will look almost like a factory edge.
Old 12-08-2011, 04:08 PM
  #87
ToyoTech559's Avatar
looks great. cant wait too see it done. now will this allow more/better engine braking since you can hold it in gear but i guess its the lock up that does it
Old 12-08-2011, 04:11 PM
  #88
Texas_Ace's Avatar
You can still engine brake without the lockup but I have never been a fan of engine breaking, puts too much stress on the rod bolts which are already a weak link in these motors.
Old 12-08-2011, 04:14 PM
  #89
i just want engine braking similar or close to what a stick shift would be on an auto. when im going down a mountain with it in 4 low and 1st gear. i have to ride the brakes to keep the engine from taking off. maybe regearing will help.
Old 12-08-2011, 04:17 PM
  #90
Texas_Ace's Avatar
You can engine brake, I just don't like it. Just Personal preference.
Old 12-08-2011, 04:57 PM
  #91
Clownmeat's Avatar
http://www.youtube.com/watch?v=t8Uxo...yer_detailpage
Old 12-09-2011, 08:18 AM
  #92
yotasavg's Avatar
that must be very exciting for you!
Old 12-09-2011, 10:45 AM
  #93
Clownmeat's Avatar
It has been a fun and relatively cheap project. It might be exciting when I actually get to use the paddles to shift it.
Old 12-09-2011, 11:01 AM
  #94
irab88's Avatar
It has been a ... relatively cheap project.
so let's see:
$20 arduino
$40 (???-- no clue, just a guess) paddles
$20 relays/components
$10 misc
+________
~$100 for paddle shifters? not too bad... that's like a $500 factory option, right?
Old 12-09-2011, 11:26 AM
  #95
Clownmeat's Avatar
Pretty close, somewhere around $60 at the moment. But that's just parts, not time, and time is money.
Old 12-09-2011, 11:28 AM
  #96
irab88's Avatar
sweet. can't wait to see the full thing in operation
Old 12-09-2011, 11:36 AM
  #97
BMcEL's Avatar
Stop it...you're making me reconsider my R150F swap.
Old 12-09-2011, 02:05 PM
  #98
Clownmeat's Avatar
Can't stop now, haven't even got to the fun part yet.
Old 12-09-2011, 03:09 PM
  #99
Clownmeat's Avatar
Might be changing things a bit as far as relays go.
Old 12-09-2011, 05:48 PM
  #100
Texas_Ace's Avatar
Are you going to use the big automotive relays or the small circuit board mounted ones?
Quick Reply: Paddle shift 4runner project
