p1126 code on 02 4runner
Old 06-10-2013, 02:04 PM
jct61765's Avatar
Hi, I've been a member here for a while. Lurking more than anything else. Last week had the 02 4runner in for its yearly inspection. Never had a problem with it. I had the belts replaced. My wife who is 8 months pregnant always drives it. It lost power on her.she shut it off waited, restarted and drove it home. Its throwing a p1126 code. I've read several threads on here with the same problem. I haven't seen anyone post definite fix. In one thread wabbit says its the A/C clutch. Any help would be appreciated.
Old 06-11-2013, 12:01 AM
wyoming9's Avatar
Red face
Try doing a google search or your favorite search engine.
My 2000 Tacoma FSM does not even list that code.
Old 06-11-2013, 10:02 AM
jct61765's Avatar
I have and it comes up as magnetic clutch circuit. It looses throttle response. In one thread wabbit says its the AC clutch. I dont have a whole lot of money right now. My wife has about 3 weeks before she goes into labor. Can I just replace the clutch? No one has had this happen to them?
Old 06-16-2013, 10:02 AM
stir_fry_boy's Avatar
I don't know if you can replace just the clutch. I know on Hondas you can and their compressors are made by denso, same as ours. You can call the stealer and see if they sell the clutch separately. I believe they do.
Old 06-21-2013, 12:12 AM
jct61765's Avatar
Thanks for answering. I'm going to check this weekend.
Old 06-21-2013, 07:21 AM
TheDurk's Avatar
It's NOT the AC clutch! It's part of the throttle-by-wire system. (Only '01-'02 4Runners have this.) See 2002 4Runner FSM below.
http://tacoma.site40.net/4Runner_96-...fe/cip1126.pdf
Old 08-20-2013, 12:28 AM
jct61765's Avatar
I was finally able to find a complete throttle body on ebay. I installing it and drove around for about 30 minutes. I tried gunned it and it hesitated for a second. It then took off. After maybe 15 seconds at 30mph it hesitated again and the same cel came back P1126. So I guess it wasnt the TPS!! Plugs and wires are fairly new, maybe 15,000 on them. I have taken extremly good care of this truck. Light 4wheeling, never beat on. I love this truck, but I'm at my wits end.
Old 08-20-2013, 05:39 PM
jct61765's Avatar
Found out today that toyota has a recall for my problem.
Its called the Customer Support Program Economic Loss Class Action Settlement.
Effective Dates are from 8/7/2013 to 8/7/2016
No Milage
It covers
Cruise control switch
Pedal Assembly
Stop lamp switch
Throttle body Assembly
Engine control module
I Hope this helps someone else.
smthwsn357
05-01-2024 07:28 AM
smiley52
07-11-2015 05:16 AM
Roger Borba II
07-09-2015 05:05 PM
Jnkml
07-06-2015 01:20 PM
coryc85
07-06-2015 04:07 AM
Quick Reply: p1126 code on 02 4runner
