Oversized 2.7L oil filters..
Old 03-17-2004, 06:05 PM
Schuey2002's Avatar
Question Oversized 2.7L oil filters..
After doing a search, and coming up empty, could someone please post a list of the oversized oil filters (Toyota, Wix, Purolator, etc.) for the (3RZ-FE) 2.7L 4-banger? Any brand will work. Thanks!
Old 03-17-2004, 07:56 PM
Away
Dr. Zhivago's Avatar
Here ya go:
Napa fil1516
Bosch 3422
Mobil M1-210
Motorcraft Fl-400S
Purolator L20195
PowerFLo L20195
I can tell you with all certainty that these filters will spin on and have the correct valving, bypass function, etc. I can't say for sure that they will fit due to space issues since I don't own a Tacoma w/ the 4 Banger. However, the same filters fit on the 3.4L V6 on both the Taco and the 4Runner. The same stock filter fits on both engines as well.
Hope this helps.
G
Old 03-18-2004, 01:00 PM
Highland Runner's Avatar
I got these off bobistheoilguy site.
Toyota oil filters
OEM Size Oil Filters
Toyota: 08922-02011, $4.91 (mini-truck, USA);
Toyota: 90915-YZZB9, (mini-truck, Japan)
Toyota: 90915-YZZB5, $4.91 (Tundra V8)
AC Delco: PF2, PF2217, SPF2, UPF2
Fram: PH3614, DG3614
K&N: HP-2004
Mobil 1: M1-204
Motorcraft: FL-793
NAPA Gold: 1068
Pennziol: PZ-21
Puralator: L10241, PL10241
Wix: 51068
Oversize Oil Filters
Toyota: 15600-41010, $12.33 (superseded by 90915-YZZB5, but still available)
AC Delco: PFL1A, PF2, PF2217, UPF2, SPF2
Fram: PH8A, DG8A, TG8A K&N: HP-3001
Mobil 1: M1-301
Motorcraft: FL-1A
NAPA Gold: 1515 (made by Wix)
Pennziol: PZ-1 (a Fram filter)
Puralator: L30001, PL30001
Wix: 51515
Old 03-18-2004, 03:08 PM
Schuey2002's Avatar
Thanks guys, that's exactly what I was looking for!
Old 03-19-2004, 06:25 PM
Guest
jruz's Avatar
Amsoil has one too...I can't think of the model number off the top of my head...
Old 03-19-2004, 07:02 PM
toy283's Avatar
In Fram alone there are several:
PH3614 - standard filter (¼qt size)
PH3600 - same diameter but longer (½qt size)
PH43 - same length but larger diameter (½qt size)
PH8A - longer and larger in diameter (1 qt size)
PH977B - larger diameter and longer than the PH8A (1½qt size)
Some of these numbers cross-reference to the same filter in other makes.
calderp
Engine Swaps
08-16-2016 05:15 PM
rondogracing
Engine Swaps
16
08-24-2015 03:02 AM
Toyvana
07-29-2015 10:47 PM
yourrealdad
07-29-2015 11:08 AM
calderp
07-27-2015 09:58 AM
Quick Reply: Oversized 2.7L oil filters..
