Overheating issues
Old 02-07-2014, 11:35 AM
YotaChick's Avatar
I tried the drilling a hole in the thermostat thing that had been suggested, worked like a charm! I love YotaTech, thanks guys!
Old 02-08-2014, 10:55 AM
CMBTMEDIC's Avatar
Okay all I spoke too soon..... She was driving beautifully..... And now she is right back to square one..... Over heating. I really am getting beyond pissed off at this now.....
Old 02-08-2014, 01:12 PM
blandis's Avatar
Pull thermostat and drive it. See if it overheats.
OEM thermostat only.
Old 02-08-2014, 10:30 PM
CMBTMEDIC's Avatar
Thermostat is from yota dealership, it doesn't heat up when the thermostat is out!
Old 02-09-2014, 10:17 AM
  #25
BMcEL's Avatar
Get a test kit to check for hydrocarbons in the coolant.
Old 02-09-2014, 10:27 AM
  #26
CMBTMEDIC's Avatar
What would that tell me?
Old 02-09-2014, 02:38 PM
  #27
blandis's Avatar
If it only overheats with your thermostat in then that would tell me the thermostat is bad.
Should not have to drill a hole in OEM thermostat. Put jiggler at 6.
Did you test thermostat on stovetop in hot water? Make sure it opens at correct temp?
Old 02-09-2014, 03:28 PM
  #28
BMcEL's Avatar
Exhaust bubbles leaking into the coolant (cracked head/head gasket leak) can cause it to overheat by building up a pocket of air in front of the thermostat, causing it to close (air can't transfer enough heat to open it). This can't be detected by testing the thermostat in hot water but a hydrocarbon test kit will tell you if there's been exhaust in contact with the coolant. They're cheap and worth the peace of mind. Even if the test is negative, you will at least know that the heads are tight / not cracked and the gasket sealed.
Old 02-09-2014, 03:53 PM
  #29
CMBTMEDIC's Avatar
I picked up a new yota thermostat and put it in a pot of water and it opened at 180 degrees. Put it in the runner.... Same issue
Old 02-12-2014, 07:58 AM
  #30
blandis's Avatar
Not sure what to tell you at this point.
Thermostat out is fine. Known good thermostat in and it overheats. I would be guessing if I were to throw anything out.
Wish I had an answer for you.
Old 02-12-2014, 08:08 AM
  #31
CMBTMEDIC's Avatar
Well and educated guesses will be accepted!!!!
Old 02-12-2014, 08:13 AM
  #32
BMcEL's Avatar
These are usually cheap and it will tell you if you have a cracked head or leaking head gasket causing exhaust bubbles to get into the cooling system. Sounds to me like that's the problem.
Old 02-12-2014, 09:04 AM
  #33
maachine's Avatar
i'd try drilling a hole in the t-stat, park it on an incline, turn heaters on full blast and run it. my guess is you have an air bubble that the t-stat is blocking and the air pocket isnt warming up enough to allow the t-stat to open.
Old 02-13-2014, 01:05 PM
  #34
CMBTMEDIC's Avatar
Okay decided to pull the damn thing apart again. The head gaskets are for sure on the correct sides, however I found a default in the bank 1, passenger, right side, head gasket. It is a multi layer gasket and one of the layers the bottom most layer had one port that wasn't punched out. So I punched out the hole, and am in the process of putting it back together.
Old 02-13-2014, 01:17 PM
  #35
blandis's Avatar
Please let us know the outcome after its back together and running.
Old 02-13-2014, 01:40 PM
  #36
maachine's Avatar
good call on ripping it apart. sucks you had to but live and learn
Old 02-14-2014, 04:49 PM
  #37
FJHammerHead's Avatar
That suxs, but it had to be done. Hopefully it fixes the problem.
Old 02-22-2014, 04:21 PM
  #38
maachine's Avatar
is it running again?
Old 02-24-2014, 08:05 AM
  #39
CMBTMEDIC's Avatar
Got it running last night, however I have two injector seals leaking. So I pulled the injectors last night. I bought some seals this morning and will be putting them in tonight. I am also going to take the bank one injectors in today to get them tested because that was the leaking bank., I will update all hopefully tonight or tomorrow with if things work.
Old 02-26-2014, 09:11 PM
  #40
CMBTMEDIC's Avatar
Okay she has been driving for the last two days without overheating!!!! My dashboard thermostat is broke now though..... Have to figure out what I did to that. But it seems to be working now!!! Thanks all for the help! Any insight to the broken temp gauge would be nice!
Quick Reply: Overheating issues
