OME 906 coils
Old 10-07-2007, 11:46 AM
  #41
alexe's Avatar
ive got 906's and 881's to go in but still undecided on what shocks to run. those of you with the ome comfort how is the ride? its not too soft is it? im looking for a firm ride that absorbs the bumps but doesnt bounce or get too out of shape. should i go comfort or medium?
Old 10-07-2007, 01:01 PM
  #42
MTL_4runner's Avatar
Originally Posted by CASTAIC 4RUNNER
hey how ya doin every body ... i have ordered ome 881's and daystar coil spacers 1" for the front and ome 906 for the rear
the shocks are n91s and n86 please tell me what you think of my combination
Ditch the spacers up front and run the 906's or use them and get 890's for the rear instead.
Those shocks will be a bit stiff (I prefer the OME comfort shocks), but that's just IMHO.
Old 12-22-2007, 10:57 AM
  #43
ciscojay's Avatar
Originally Posted by johnw999
With your setup of ome 881 and 906, is a differential drop, extended rear brake line, or adjustable panhard needed? I have the 99 springs, and I'd like a little more lift.
Originally Posted by MTL_4runner
Nope.....as long as you don't use any spacers up front.
To those running the 906 springs,
I'm awaiting my 881/906 springs to show up, but I'm still concerned that the rear axle might kick out to the passengers side a bit unless I put in the SS panhard bar. Are you still running this setup and if so any problems so far?
I've been running the PP 1" springs and unless I have a lot of weight in the vehicle they are just too stiff. Performance-wise, they handle great on the road...don't even consider offroad, they suck. It's not right when you see a bump or dip in the road and you have to brace/tense up a bit before you roll over it.
Thanks,
Jay
Old 12-22-2007, 01:13 PM
  #44
Gerdo's Avatar
Jay
I have 890s and I didn't do anything with my PH bar. My axle may be off by 1/8". Not enough to wory about. After thousands of miles I haven't felt anything bad either. That is without a load also so that will be less with a load. 906s are shorter, I wouldn't worry about it.
Old 12-22-2007, 01:28 PM
  #45
ciscojay's Avatar
Thanks for the info, just the answer I was looking for. That adjustable panhard is pricey. I can't wait to put these on!
Old 12-23-2007, 05:46 AM
  #46
Originally Posted by Gerdo
Jay
Ditto.
No panhard adjustment needed for the 906's
The 890's are borderline, but again I ran them fine without also.
Old 12-23-2007, 12:43 PM
  #47
Weekend_SR5's Avatar
MTL_4Runner..Can you post a picture with your 881/890 and 881/960 combinations. I still cant decide if I want 890 or 960. From what I read, If i get 890 spring and install without cone bumpstop it is equivalent to a 960. Is this correct? Is that .5 a difference from a 890 to 960 visually noticeable?
Old 12-23-2007, 02:26 PM
  #48
Yes, the difference is definately noticable (esp gas mileage)
Here's the pics with each combo:
http://www.ultimateyota.com/index.ph...26&topic=331.0
Old 02-16-2008, 12:59 PM
  #49
warriors_03's Avatar
MTL - I just recently go the PP 1" with bilstein's all the way around, and its much better than before, but I must say that I think its a little too stiff now. I was reading about the 881/906 setup. How much difference in height do you think I will see from the PP to the OME, and how about the ride difference?
Thanks,
Mark
Old 02-16-2008, 01:44 PM
  #50
shiftMX's Avatar
from my experience, there was about a 1/2" less with the OME coils but the ride was not as stiff as the PP's. I much preferred the OME coils
Old 02-16-2008, 02:47 PM
  #51
One_96TR4's Avatar
Thanks,
Mark
I think the stiffness is more due to the bilsteins than the PP springs. Many ppl complain about the Billies being too stiff.
Old 02-17-2008, 06:53 AM
  #52
Yeah, I have heard that one too. I know that they are one of the best shock/strut out there, so I figured better take care of the runner...Plan on keeping it a few years...
Old 02-17-2008, 10:05 PM
  #53
One_96TR4's Avatar
I personallyt have the Tokico Trekmasters and I think there great. I have them paired with the Tundra/OME lift and have no complains. ~200 for a set and they have a lifetime warranty.
Old 02-18-2008, 06:45 AM
  #54
X2
The OME's are definately stiffer than stock but not nearly as harsh as the PP / Bils combo.
Old 02-18-2008, 11:39 AM
  #55
shiftMX's Avatar
Just some FYI, I had the trekmaster shocks...not the billies with the PP springs. They were still stiffer than the OME coils. I ran both coils with the exact same shocks.
Old 02-18-2008, 04:39 PM
  #56
Exactly, the PP springs are stiffer than the OME coils for sure.
That's why the PP / Bils combo is so harsh.
Old 02-20-2008, 06:29 AM
  #57
X2
Thanks, sounds like where I am headed. My next question is on trdparts4u, the site states that you must use OME's nitro charged shocks with their coils. Is this true or is there a way to work around my billies? Or do I need to make a full swap?
Thanks,
Mark
Old 02-20-2008, 06:39 AM
  #58
Thanks,
Mark
If you want it to ride nicely, then sell your bils to someone who wants the stiffer feel.
My ride suggestions are based on the OME setup as I have in my sig.
Old 02-20-2008, 08:37 AM
  #59
Right. Makes perfect sense. But, if I want to hold onto the billies, will they work with the OME's? Just wondering if they even will, if you know.
Thanks,
Mark
Old 02-20-2008, 08:59 AM
  #60
Also, how much space do you have between the cone bumpstops and the axle?
Quick Reply: OME 906 coils
