is it ok to revert back to dino oil from synthetic blend?
Old 01-20-2005, 10:47 AM
Amir904's Avatar
the 85 4runner i just bought has been getting synthetic blend oil changes. is it ok to revert back to dino oil? i hear once u change to full synthetic, its not a good idea to go back to dino. does the same hold true for synthetic blend?
Old 01-20-2005, 10:48 AM
WATRD's Avatar
People have reported additional drippage from already existing drips going in either direction, but functionally, there should be no problems. Both synth and dino contain additives to be more friendly to seals, so the old problem of drying them out is not a problem anymore. If anything, the change back to dino should be easier than the swap to synth because you don't have all the crud getting cleaned out that you have when you go from dino to synth.
Old 01-20-2005, 11:04 AM
ChickenLover's Avatar
You should be alright. I switched back to dino after my full synthetic started leaking when the engine was pushed hard. I haven't had so much as a drop leak out after the switch back to dino 20k ago.
Old 01-20-2005, 11:10 AM
HaveBlue's Avatar
You'll be fine, expecially since you're switching from a blend.
Old 01-20-2005, 11:16 AM
sherri_girl's Avatar
What brand of synth are you guys using?
Old 01-20-2005, 11:25 AM
Amir904's Avatar
almost 40% use Mobil 1, check it out
https://www.yotatech.com/forums/show...ight=motor+oil
Old 01-20-2005, 11:31 AM
WATRD's Avatar
Amsoil all around in my rigs.
Old 01-20-2005, 11:32 AM
Good Choice
Old 01-20-2005, 11:38 AM
kyle_22r's Avatar
i've heard stuff about amsoil's viscosity increasing over time?
after a couple thousand miles on 5w30 dino oil in my new engine, i think i'm going to try some shell rotella 5w40 synthetic.
Old 01-20-2005, 02:30 PM
WATRD's Avatar
News to me I have been using it for a few years and the oil analysis has never indicated that problem. Got links?
bigjstang
08-25-2021 12:41 AM
Yota.Jay
07-23-2015 08:08 PM
Gamble_STi
07-07-2015 07:54 PM
HRDC0R19
07-05-2015 06:43 PM
elwood73
07-05-2015 07:07 AM
Quick Reply: is it ok to revert back to dino oil from synthetic blend?
