Is it ok to....
Old 06-02-2004, 07:51 PM
Sunday BBQ's Avatar
Is it ok to....
One the car is cooled down, pull a battery cable or two and just hose off the entire engine bay. It's really muddy since we went playing in the mud and I don't want it to take a million minutes. I want to just hose the darn thing off. I'd let it dry before starting it though. What do you think?
Old 06-02-2004, 07:55 PM
Marc P's Avatar
I am not a big fan of washing an engine--but if you are going to do it, keep the engine running during the whole process--and use as little water as possible.
Old 06-02-2004, 07:56 PM
terky's Avatar
should be fine, just watch out for the distributer. And just to be safe when you are done spray some WD-40 around the dist. and let it sit a minute.
Know what WD-40 stands for?
Water Displacement Formula 40. Invetned by nasa to use on circuit boards. Techs started sneaking it home and figured out alot of good uses.
Old 06-02-2004, 08:00 PM
Sunday BBQ's Avatar
Keep it running? I think that's exactly what you wouldn't want to do. I'm not talking just the engine, which would be steaming by the way, but I'm talking about the whole engine bay.
Old 06-02-2004, 08:03 PM
terky's Avatar
Yeah i wouldnt keep it running either. You arent even supposed to add cold water to the coolant when the truck is running.
Everything in the bay can handle low pressure water, its when people bring out the Presure Washers that they get into trouble.
Old 06-02-2004, 08:08 PM
Birdman's Avatar
Keep it running? What is the logic behind this?
Old 06-02-2004, 08:37 PM
User 051420's Avatar
I've never had a problem hosing my engine with a high pressure washer. Turn off the engine, hose it off, keep going.
Old 06-02-2004, 10:37 PM
bulldog-yota's Avatar
DOnt worry just hose it down wash it and hose it off. What do you think happens when people drive through deep water, especially with the fan spraying it all over the engine compartment?
Old 06-02-2004, 10:56 PM
Phoenix12's Avatar
I give a "medium" pressure soak to loosen the mud and grime and wipe what I can with a wet rag, then give everything rubber or plastic a good shot of tire foam. Looks like a new engine. WD40 is a good call on the distrib., though in AZ we don't worry too much about water sitting on parts very long.
Old 06-02-2004, 11:30 PM
flecker's Avatar
Location: White Mountains, Arizona (Yes it does snow in AZ)
Aw Come on... douche that puppy, nothing will happen. And don't run the engine while your doing it I just use simple green and armor all on mine. turns out graet!
Old 06-02-2004, 11:43 PM
ilion's Avatar
The meaning I've read is, "Water Displacement on the 40th try."
And it predates the silicon chip and board; it was for cleaning and lubing rocket parts in the 50's.
Dig It!
Old 06-03-2004, 12:23 AM
Maddog's Avatar
I used to steam clean alot of engine bays when i was younger,& never had any problems,you may have to clean up the distributor cap if it runs rough afterwards but that s all that should be a problem.just try not to spray directly at it.
the worst thing that ever happen was the time i reversed out of the cleaning bay & the door flew open ,bent the thing in half ,boss wasnt happy
Old 06-03-2004, 03:53 AM
SLC Punk's Avatar
Yep, just watch out for the electrical stuff (i.e dist) like said before. I washed the engine all the time on my 94 Ranger. I have only one it once on my 4Runner. But have never had a problem.
Old 06-03-2004, 05:16 AM
metalhed's Avatar
Greetings So unlike some chevy products, we can wash the whole engine without fear of shorting out or killing any TPS switches?
I ask cuz the new truck (2001 Tacoma) is light years different from the old truck (1984 pu) thanks
Old 06-03-2004, 05:46 AM
My99's Avatar
This is a yota, I've never had trouble, high pressure or garden hose pressure with water. The 90 I've been working on was filthy. TOok it to the carwash, popped the hood, sprayed everything down with some purple degreaser stuff. Let sit for about 10 mintues or so. Brought out the "rinse" cycle and gave it a good once over for about 2 or 3 minutes. Didn't unplug anything or cover anything up. If your distributor is not sealed well you COULD have a problem, so this would be my only concern, and I didn't intentionally try to spray water in mine either. I got done, hit the key, and it fired right up as normal and I drove away. I've done this on all my yota's. I don't advise having the motor running. The fan is quite a nuisance, and it'll fling water all over everything.
Old 06-03-2004, 06:17 AM
Highland Runner's Avatar
Use high pressure don't worry about it. Everything is waterproof or will dry quickly from engine heat. The distributor is o-ring sealed. The only thing I don't spray directly is the fuse box. I've used a pressure washer on all my Toyotas for years with no problems. Spray the engine bay with tire foam when you're done.
Old 06-03-2004, 06:18 AM
DavidA's Avatar
I have powerwashed my Toyota engines for years, I take them to the carwash, pop the hood and spray them down. Don't be afraid of them.
Old 06-03-2004, 08:52 AM
ewarnerusa's Avatar
I always wash my engine bay. I use simple green, let it soak for a few minutes, then spray it off. I have heard of people ruining alternators and stuff, so I stay away from directly spraying that. But other than that, spray away. My engine bay looks as clean as it was when I first drove it home.
Old 06-03-2004, 09:22 AM
dcampen's Avatar
WD-40 history:
http://www.wd40.com/AboutUs/our_history.html
Old 06-03-2004, 12:28 PM
Maddog's Avatar
really !!! I must try that
Quick Reply: Is it ok to....
