oil under my air filter?
Old 02-11-2007, 09:19 PM
BajaRunner's Avatar
I too get oil coming from that same line. The top line that comes into the intake.
I have no idea why its coming, and do not get as much as you, but, probably had a good tablespoon in the ridges along the intake tube.
Anyone else have a clue why this is happening?
Old 02-11-2007, 09:26 PM
Elton's Avatar
thats weird i must have a very healthy engine my pcv valve has 144k on it and its fine also they way ive heard to check the pcv valve is if it rattles its fine
Old 02-11-2007, 09:27 PM
Lifted96's Avatar
Ya I'm not sure how long it took for that reservoir to fill up. who knows. I've only had this car a few weeks, and I'm not sure how long its been since the prev owner removed that hose. Hopefully next time a check it. there isnt much in there.
Old 02-11-2007, 09:28 PM
Lifted96's Avatar
Originally Posted by Elton
thats weird i must have a very healthy engine my pcv valve has 144k on it and its fine also they way ive heard to check the pcv is if it rattles its fine
ya i've heard that too. My old one rattled. but I thought for $2.65 it didnt hurt to buy a new one.
Old 02-11-2007, 09:32 PM
  #25
Elton's Avatar
hmm 3 bucks why not i may as well toss my old one
Old 02-11-2007, 09:55 PM
  #26
neilan's Avatar
well that looks like more than the normal small amount of oil that does pass through that tube. I would say look into the pcv catch can mod but you look to have mroe than the normal amoutn of oil so look into findign otu why first then consider the mod so you intake doesnt gunk again.
Old 02-11-2007, 10:12 PM
  #27
Lifted96's Avatar
ya I think its coming from that vac hose pictured. IIRC its attached to the driver side valve cover. I wont get another chance to mess w it until next sunday
Old 05-14-2007, 07:56 PM
  #28
FJ40Josh's Avatar
I also have a little oil under my air filter. It has been there for as long as I have had the truck. It has been about a year and a half. It is a 97 4runner with the six.
Old 05-15-2007, 05:43 AM
  #29
Gerdo's Avatar
I would still bet it was the PVC. Even bad ones will let air thru and rattle. If it starts to stick while driving the engine will start to pull air from the return tube and suck oil. Pressure build-up will cause oil to come up that tube. That is one of those things that you just replace every once in a while. Change the PVC, clean out the air tube and air box, replace the air filter, clean the MAS.
Old 05-15-2007, 06:05 AM
  #30
mt_goat's Avatar
X2, I did the catch can mod on that tube but so far I haven't seen a drop of oil in it, not that I'm complaining.
smthwsn357
05-01-2024 07:28 AM
the1998sr5
15
07-14-2020 08:35 PM
Eggslinger
06-08-2019 03:32 PM
Alex Bessinger
08-31-2015 09:17 AM
ryerye13
07-14-2015 08:27 AM
Quick Reply: oil under my air filter?
