oil under my air filter?
Old 02-02-2007, 12:58 PM
Lifted96's Avatar
I noticed that I Have oil under my air filter. any ideas what the problem coudl be? I have never seen this before.
I appreciate the help
Patrick.
Old 02-02-2007, 01:19 PM
neliconcept's Avatar
K&N filter? come over oiled from the factory, any filter that has a recharger kit can do that
Old 02-02-2007, 01:26 PM
Lifted96's Avatar
I dont think its a rechargeable filter, it looks stock. unless 4runners came w them?
Old 02-02-2007, 01:46 PM
Lifted96's Avatar
heres some pics.
Old 02-06-2007, 09:29 PM
Lifted96's Avatar
anyone?
Old 02-06-2007, 09:33 PM
Elkaholic's Avatar
wow Im sorry I dont have any help but the same thign happened on my quad. I could never figure out the reason.
From that first pic, it looks like its coming down the tube that is aft of the filter. Is it?
Old 02-07-2007, 12:12 AM
mpavolka's Avatar
I had the same problem with my old 4Runner, the whole intake was full of oil. Sorry to say that I don't know what caused it either. There might be a few vacum lines that connect to the valve covers, in this case that would probably be where the oil is coming from, but I don't know.
Old 02-07-2007, 12:20 AM
Guest
seanz0rz's Avatar
in my honda it was caused by over filling the oil/bad pcv valve and it was throwing oil back into the intake.
Old 02-07-2007, 12:24 AM
mpavolka's Avatar
Yea I would try replacing the pcv valve, then clean the intake and check again later.
Old 02-07-2007, 07:21 AM
Elton's Avatar
x2 on the pcv takes all of 5secs to replace it but i would get some intake cleaner and clean the tube real good and the throttle body and then clean the maf with ether electrical contact cleaner or maf cleaner
Old 02-07-2007, 07:24 AM
bob200587's Avatar
wish I could say the same for the 22RE. That little grommet makes the PCV hell to get out.
Old 02-07-2007, 10:31 AM
Bennito's Avatar
x3 on PCV (and clean box so you can tell if it happens w/ new PCV). If it does, you might want to check compression (my thought would be ring blowby).
Old 02-07-2007, 12:50 PM
toyotaoffroad91's Avatar
STOP doing wheelies!!! but if you must continue change your PCV first
Old 02-07-2007, 07:56 PM
Lifted96's Avatar
thanks guys. I'm going to my dad's this weekend and i'll get it swapped out. Hopefully that's all it is. I'll keep you guys posted.
Thanks again .
Old 02-07-2007, 08:01 PM
Elton's Avatar
while you have the intake all tore apart do i hear deckplate mod and isr mod ?
Old 02-07-2007, 08:30 PM
Lifted96's Avatar
not sure what those mods are... so i guess i'll be doing a search
Old 02-07-2007, 08:32 PM
Elton's Avatar
https://www.yotatech.com/forums/f130/
Old 02-08-2007, 02:34 AM
grimpy's Avatar
If you change the PCV valve... get a new grommet (sp?) as well... The rubber hole the PCV valve plugs into... I just got a new one and when I removed the old grommet, the crap just cracked into three pieces...
Old 02-11-2007, 06:45 PM
Lifted96's Avatar
well guys we took a look at it today. Can't you check to see if a pcv vavle is good by blowing on it and one side should let air out and the other should not? the old pcv valve did that, but the one that we replaced with allowed air both ways? anyways. the tube leading to the intake was lined with oil and the little "reservoir" was full of oil. I am not sure how long it took for it to fill. We did a dry compression check and all cylinders were ~160. it seemed a bit low, but at least they were all pretty much the same. We also noticed that the oil seemed to be close to a quart over.
maybe from here?
I appreciate any ideas you may have.
Thanks again.
Old 02-11-2007, 06:51 PM
kmchby76's Avatar
Originally Posted by Lifted96
I do get a litte oil from here myself. not sure if it is considered normal or not.
Quick Reply: oil under my air filter?
