Oil pressure sending unit
Old 07-04-2012, 11:45 AM
Simon's Avatar
Exclamation Oil pressure sending unit
Hi guys, its been a while since I posted as my 4Runner has been running great. So today I changed the oil and as I was taking off the oil filter, the wrench slipped and busted off a screw on piece right next to the oil filter. It has a spring in it and looks like a sensor of some sort. The truck runs fine and I will get it replaced ASAP, but I was wondering if anyone knew what the sensor actually does and if its ok to drive the truck in the mean time before I bring it to the dealer. Here some pics.
As always, thank you to all the great people and info on this site!! Oh yeah, Happy 4th of July!!!
Old 07-04-2012, 11:30 PM
anthony1's Avatar
That looks like an oil pressure switch.....not a sender.
It's the kind that goes to the light not a gauge.
Old 07-05-2012, 01:51 AM
Staff
Terrys87's Avatar
I would replace it as soon as possible. It is under alot of oil pressure and if it pops a leak, it will spew oil out fast.
I was swapping one from the light to the guage and the head of the unit busted off leaving a hole right threw the center of the threads. Take your time getting it off. Make sure you get a good fit with the wrench.
Old 07-05-2012, 05:17 AM
Texas_Ace's Avatar
Are you getting any lights on the dash? I would pick up another switch, a place like pepboys should have the right part for cheap.
Old 07-05-2012, 06:07 AM
Simon's Avatar
Thanks guys for the replies. No lights on the dash. Most of the piece is still screwed in so I don't think there is a chance oil will come out, but I hadn't thought of that possibility before.
Mr. Ace, you think an autoparts store would stock it? I thought it may be something I could only pick up at the dealer, but I'll check around at some of the autoparts stores first. Thanks again!
Old 07-05-2012, 06:08 AM
Texas_Ace's Avatar
Yep, an oil pressure switch is a pretty common part. They should have one. I picked one up for my MR2 for $18 IIRC.
Old 07-07-2012, 01:21 PM
pattycakes77's Avatar
I don't know if it's the same thing but...
https://www.yotatech.com/forums/f2/o...-5vzfe-247947/
Maybe it will help you out, maybe not. The plastic on mine was cracked a little and spewed oil like crazy!
Old 07-20-2012, 08:27 AM
Simon's Avatar
Yep, that is the same part. Mine wasn't leaking though since most of the sensor was still screwed in. I got the 12.99 one from Advance Auto and it installed and is working. I assume. Since I can't tell a difference with it plugged in or not. Thanks guys!!
Old 06-16-2014, 12:13 PM
PW4Runner's Avatar
Hi,
I see that this post is already a couple years old, but can someone tell me what the Toyota part number is for this oil pressure switch? I have a 2000 4Runner 3.4L. My switch has been leaking since my last oil change so I need to replace it but need the part number.
Thanks very much!!
Old 06-16-2014, 04:27 PM
rworegon's Avatar
Looks like possibly 83530-0E010 from here and here.
The following users liked this post:
LevanM (09-02-2021)
Old 06-18-2014, 02:54 PM
PW4Runner's Avatar
Thank you very much!!
Doug4320
03-24-2018 10:11 PM
skoti89
09-11-2015 07:46 AM
Odin
07-15-2015 09:28 PM
88yodabasket
07-13-2015 01:32 PM
Tyler Cunningham
07-11-2015 10:18 AM
Quick Reply: Oil pressure sending unit
