Oil Pan will not seal on a 3.4L
Old 04-11-2013, 02:11 PM
traxxi2003's Avatar
Hello everyone!
So, I've trying to re-seal the oil pan but no luck. The pan is leaking where it comes in contact with the timing cover, I was told by a friend to only apply the gray RTV, without using the cork gasket, and still leaking really bad. Any suggestions? Should I used the gasket and RTV? I'm on my third attempt to seal this damn thing!!!!!
Old 04-11-2013, 02:22 PM
rworegon's Avatar
Pick up a tube of oil FIPG from the nearest Toyota. Be sure the sealing surface is smooth, debris free, and wipe both mating surfaces with a solvent like carb cleaner or acetone before applying the FIPG. The FIPG has a short open time so be ready to get the pan on and torqued down pronto.
Old 04-11-2013, 02:29 PM
traxxi2003's Avatar
DO I still use the cork gasket with it?
Old 04-11-2013, 02:39 PM
rworegon's Avatar
No. The Toyota FIPG is all you need to use.
Old 04-11-2013, 02:41 PM
donomite49's Avatar
no, fipg(form in place gasket)only. like stated above clean surfaces with contact cleaner or something.
Old 04-11-2013, 02:48 PM
rworegon's Avatar
Toyota FIPG part numbers are here.
Old 04-11-2013, 03:28 PM
DRCOFFEE's Avatar
I cant believe they still sell cork gaskets when there are modern gaskets like Felpro. Ditch the cork, get a quality gasket from Felpro and apply a thin film of oil resistant RTV on both side and torque it down. The FIPG works at the factory because they have a clean dry surface. Its almost impossible to stop oil from draining from the block on a used motor.
Old 04-11-2013, 05:00 PM
98SR54RUNNER's Avatar
As others have said, do not use cork or other pre-formed gaskets. The pan seals best with a form in place gasket. Toyota FIPG or RTV will work fine. I've used RTV and never had a problem with it leaking and I've dropped the oil pan a couple of times. I'd make sure your pan isn't bent or something. Also, make sure the mating surface is clean. Get a wire brush on the drill and that makes easy work of scraping the old stuff off clean.
jasonty
41
12-23-2018 01:00 PM
09-04-2015 09:27 AM
thefishguy77
07-30-2015 10:59 AM
irritech
07-27-2015 05:15 PM
1996Taco
07-20-2015 12:02 AM
Quick Reply: Oil Pan will not seal on a 3.4L
