Oil Light Flicker
This is very interesting, I found this in my official Toyota 1998 4runner Owners Manual, Chapter 1-5 p.69:
"(d) Low Oil Pressure Warning Light
This light warns that the engine oil pressure is too low. If it flickers or stays on while you are driving, pull off the road to a safe place and stop the engine immediately. Call a Toyota dealer or qualified repair shop for assistance.
The light may occasionally flicker when the engine is idling or it may come on briefly after a hard stop. There is no cause for concern if it then goes out when the engine is accelerated slightly.
The light may come on when the oil level is extremely low. It is not designed to indicate low oil level, and the oil level must be checked using the level dipstick."
Wow, that is interesting! I will have to find that passage in my owners manual.
I have been advised to change the oil with a good filter and some heavier weight oil. If I keep getting the flickering light after that, I'll have the pressure read.
FWIW, I have the same problem, exactly as the owner's manual states. It rarely happens, but mainly if I'm hitting the brakes hard to a stop, in gear, and pointing downhill. The second I blip the throttle, even just slightly, it goes away. I'm still going to get the oil pump and gauge/sending unit checked (not the $tealership though!) I'm up at that range (170k+ miles) where I'm more paranoid about stuff failing...especially something like this.
#25
Is the ground expensive? My 04 4R V6 Sport is doing the same thing. The oil pressure light isn't flickering anymore, it remains solid. The engine light , stability, and trac are lit up on the dash as well now. The engine is ticking and I can tell its running different! I parked it as soon as all the lights came on the dash, and I haven't started it back up. It's at 204,000 miles and I know that's a lot.
The following users liked this post:
millball (10-26-2019)
#27
