Oil Filter Relocation Kit...
Old 06-02-2019, 07:52 PM
TrailTrek2Fish's Avatar
3rd Gen Oil Filter Relocation Components...
Thought I'd share this with y'all...
I finally have time to perform the timing belt, water pump, etc, job. I planned to also install this oil filter relocation kit since I was gonna be in there wrenching away. Sorry for not taking progress photos but at least I took some post work photos. I decided to mount it there because the splash shield can protect the oil filter from road and trail stuff and the unit still remains out of the way of other engine components. I could of opted for an external oil cooler but chose not to, for now at least. I could have also purchased one of those fancy non-marring wrenches to keep the fitting pretty but prettiness wasn't my ultimate goal. I may add an oil pressure gauge in the near future...
It's a fairly straight forward install if one is mechanically inclined, as most of you are. The only thing I needed to fab up was the mounting plate (3"x4"x.25") for the oil filter mount. In photo #3, the upper hex is fasted to an already existing threaded (M8x1.25) mounting location on the frame. I only had to drill and tap (M8x1.25) another hole below the existing one for the second hex. I used lock washers, fender washers + red Loctite for those fasteners. All of the hardware is Stainless Steel (M8).
The following components were utilized:
Earl's Billet Spin-On Adapter 1178ERL
Earl's Billet Remote Oil Filter Mount 2077ERL
Aeroquip Male AN to Pipe Adapter FCM5088 (2)
Aeroquip AQP Hose Fitting FCM4033 (2)
Fragola Radius Fitting 495104 (2)
Aeroquip AQP Hose Fitting FCM4413 (2)
Fragola Nylon Race Hose (Less than 1" was utilized)
Old 06-04-2019, 02:41 AM
aowRS's Avatar
Very nice install.
Andreas
Old 06-04-2019, 06:42 AM
Thanks bud.
2000t4r
12-28-2004 06:47 AM
Buddyman
09-09-2004 12:41 PM
Ilovemountains
11
07-31-2004 08:56 AM
obxfishn
03-19-2004 08:06 PM
ManyMods
17
02-20-2003 03:37 AM
Quick Reply: Oil Filter Relocation Kit...
