OEM Mudflaps for 4Runners w/o flares
Old 01-23-2009, 03:07 PM
DavidAlexander's Avatar
Here are the oem mudflaps for all that need them after removing their flares.
Some people had said you can't get them anymore so here is all the info on them. They are still available but I don't know how many are left in the US.
OLD EL Cheapo flares
[/IMG]
[/IMG]
NEW OEM
[/IMG]
[/IMG]
[/IMG]
[/IMG]
[/IMG]
[/IMG]
Installed- I took the front pic with one more screw to install. Just so you all know.
[/IMG]
[/IMG]
[/IMG]
[/IMG]
And a look at the clearance with 2.5" lift and 265/75r16's
[/IMG]
[/IMG]
Comes with all the mounting hardware and uses existing holes. (No Drill)
Looks much better than the generic flaps and blends nicely with the lines of the car.
Old 01-23-2009, 03:19 PM
Ned
Ned's Avatar
Looks great... Do you know if the fronts happen to fit Runners with the fender flares, but with the running boards removed? Or are the El Cheapo ones the only option? Anyway, lookin good my friend! Nice improvment.
BTW, the cost?
Old 01-23-2009, 03:31 PM
These do not match up with the sr5 flares. Those are a different part number that I have seen on here before but don't know off hand. Thanks, Ill try to get some more pics up of how they look from different angles in case anyone is debating on getting these.
Old 01-23-2009, 03:42 PM
mikes19984x4's Avatar
looks good...i actually prefer the look of mine taken off, as it seems to make the tires look bigger...just my opinion...
Old 01-24-2009, 10:43 AM
Ron Helmuth's Avatar
very helpful that you showed the part numbers and good shots too-you look to have gained quite a bit of clearance of body from the tires with your lift.
Old 02-04-2009, 07:34 PM
henshman's Avatar
mudguard question
I looked these up by PN#...about $36 a piece.
Did you get them from the dealer?
Looks good.
Old 02-04-2009, 07:43 PM
VSU_4runnin's Avatar
i took mine off as well, it only had the rear ones though b/c of the running boards, if anyone needs the rear not el cheap-o flaps for runners with fender flares... if any one wants them ill throw em up on ebay buy it now + shipping.. for $20 (OBO) per... Pm me..
06-01-2021 01:51 PM
icentropy
09-16-2020 02:47 PM
BeMiceElf
10-10-2015 09:40 PM
09-04-2015 09:27 AM
horunner1x
07-10-2015 06:33 AM
Quick Reply: OEM Mudflaps for 4Runners w/o flares
