OEM mini header install for 2.7L*(Pics)*
Old 06-18-2014, 02:46 PM
  #181
netsomnia's Avatar
Is the 2RZ exhaust manifold known for the same problem? Is 'tick tick tick' the main symptom to be aware of or can funny vibrations when letting off the gas and rough idle be other sure tell signs?
Old 06-18-2014, 03:00 PM
  #182
Staff
DeathCougar's Avatar
Yes, as the 2RZ and 3RZ are identical manifolds.
I sell a Mini-header conversion kit that uses all OEM parts. The link is in my signature line, or you can pm me for more details.
Old 01-16-2015, 12:07 AM
  #183
86bedlesstoy's Avatar
sweet upgrade from the dealer
Old 02-01-2016, 04:05 AM
  #184
Up&Down's Avatar
DC et al., I have a few questions I was hoping to get cleared up. But first, thanks to all those that provided great info to everyone, and especially DC.
1. Does the mini-header fit both 2rz and 3rz 1995.5-2001? or just 3 rz?
2. Should one replace the threaded studs in the head? or just the studs on the downpipe?
3. Is this mini-header what they installed on 2001-2004 3rz engines as an upgrade?
4. Does the mini-header install kit come with a heat shield that fits?
Old 02-01-2016, 10:52 AM
  #185
Staff
1. All 3RZ, and 95-2000 2RZ. Starting in 2001, the 2RZ went to a difference header design and it's not necessary for this mod.
2. Sometimes the head studs pull out, so it just depends what happens when you pull the nuts off the manifold
3. Yes, this is stock equipment for 2001-2004 3RZ
4. We offer 3 different kits, and one does include the correct heat shield
Old 06-03-2016, 07:07 AM
  #186
Up&Down's Avatar
Just made the order. Hopefully this gets me another 100K on the Taco. Thanks again DC for the advice and guidance.
Old 06-03-2016, 11:08 AM
  #187
Staff
Thanks a bunch, they'll get that sent right out!
Old 08-08-2016, 03:51 PM
  #188
bigairjunkie's Avatar
Amazing thread guys! Im putting a new manifold on my 98 2.7 L.
Does anyone know the torque specs for the manifold to header studs? The studs walked out on me... Im getting mixed reviews online, it sounds like people are going hand tight?
Thank you.
Old 08-08-2016, 07:20 PM
  #189
Up&Down's Avatar
36 ft/lb
Someone correct me if I'm wrong!
You won't regret the upgrade. Did mine just before traveling from Maine to Washington. No issues.
Old 08-09-2016, 05:57 PM
  #190
Thanks Up&Down!
I was wondering more if the studs themselves need to be torqued into the block? My studs came out, and Im putting in new ones. If those are just hand tight, and the nuts on the studs are 36 ft/lbs then I'm good!
Old 05-03-2017, 08:21 AM
  #191
RustBucket's Avatar
I was wondering if a non-CA emissions vehicle, currently registered in CA, would have any smog check problems if the stock cast iron manifold is replaced with this OEM header?
DC confirmed that he has never had an issue like this but I wanted to hear from others who have done this mod in CA if you've had an issues with SMOG at all. Thanks!
Old 10-06-2017, 06:15 PM
  #192
Hrddrvs's Avatar
Question
Is there a difference in design between CA and FED? I have a FED but dealer gives me CA part number. He also has a FED number but CA number is the part for me. Strange!!! 2000 2.7 Maybe it's because I'm in CA but that would mean they are the same exact design with two part numbers. Ughhh!!! Anyone have experience with this? Thanks in advance.
Old 10-09-2017, 10:58 AM
  #193
Staff
AFAIK the 2000 Cal emissions was the header style, while 2000 FED was the manifold style.
Look at your manifold...is it cast or tubular steel?
Old 02-10-2024, 12:06 AM
  #194
Kyle 1999 2rz's Avatar
Still have these kits?
Do you still sell this kit need one for a 1999 2rz ?
Old 02-13-2024, 10:53 AM
  #195
Staff
No, toyota does though
09-04-2015 09:27 AM
tj884Rdlx
08-28-2015 12:04 PM
Esibnitsud
07-30-2015 08:21 PM
Coreyr384
07-10-2015 11:13 AM
Edionne13
07-09-2015 01:59 PM
Quick Reply: OEM mini header install for 2.7L*(Pics)*
