OEM mini header install for 2.7L*(Pics)*
Old 10-27-2008, 04:55 PM
96redtoy's Avatar
So this all started the other day when I was driving down the road with the windows down and the music off.
I was driving past some of those concrete highway dividers and heard the tell tail sign of a exhaust leak - tick tick tick
after further lissening (standing next to truck as some one drove) it was true
Since I have the 2.7L I knew it was the manifold.
After a brief time and a few choice words I found this-
heat sheild
the crack
I will be getting the exhaust mainfold from a 01+ 2.7L
they are like a mini header that bolt right up to the factory down pipe
part# 17141-75080 this is a direct bolt on they run around $150 from the dealer
Here are some pics of this manifold not on my truck-
I will be posting more picture as I go step by step
Old 10-27-2008, 05:31 PM
toyota4x4907's Avatar
Those are cool! I want mini-headers for my 22re
Old 10-27-2008, 05:33 PM
Staff
DeathCougar's Avatar
You caught that crack at the perfect time. I have seen manifolds cracked completely in HALF! Apparently people don't understand how bad exhaust leaks can be...ie suck a valve!
Thats a good swap idea on the 2.7L manifold. Definetly do a swap, and talk to Corey about making it a sticky. It my be a permanent fix to the terribly designed 2.7/2.4 manifold design.
Old 10-27-2008, 06:00 PM
96redtoy's Avatar
Will talk to Corey about this swap becoming a Sticky
yeah they are the best replacment in my mind because -
they are going to seal and stay sealed
toyota made them
they flow better then the old ones
complete bolt up
TTORA has a lot of info over there on this swap
Old 10-28-2008, 03:31 PM
96redtoy's Avatar
Went to the stealership and got a quote for $265 which is crazy. Everybody that has done this over on TTORA say 150-180 out the door at there stealership so now I am going to start calling around to find a used one.
Old 10-28-2008, 05:51 PM
Staff
If they told you $150, they were simply NOT using Factory toyota parts from the dealer.
http://www.trademotion.com/partlocat...layCatalogid=0
List price on that manifold from toyota is $227. $265 is still way too high, so talk to Strap22 on here and get a discounted price!
Or just go to that link I sent you above.
Old 10-29-2008, 08:26 AM
96redtoy's Avatar
Thanks alot DC
That linked price is much better
Are those a OEM part or some knock offs that will not seal what so ever.
Old 10-29-2008, 09:02 AM
Staff
Those are OEM factory parts, from Toyota of Dallas.
Old 10-29-2008, 09:14 AM
96redtoy's Avatar
Thanks alot that is what I thought
Old 10-30-2008, 08:05 AM
CDUFF7's Avatar
I want one too!!!!!
Old 10-30-2008, 12:56 PM
96redtoy's Avatar
just order from linked above
emailed them and whithin 30mins got a reply that somebody actually wrote and was very helpful
great website will use them again
Old 11-02-2008, 06:46 AM
riverrat's Avatar
I'm in the market for a mini-header upgrade for my 2000 4runner. I was planning to upgrade the rest of my exhaust- i.e. free flow cat and muffler- at the same time, but I'm struggling with the decision between 2.25" and 2.5" for the pipe.
I've heard from at least 2 knowledgeable people that its best to go with 2.25" on this 4 cylinder motor in order to maintain proper back pressure and torque. But others say 2.5" is the way to go.
I measured the stock pipe and it appears to be 2.25", at least on my truck. So maybe I should just get the mini-header and leave it at that for now.
***EDIT*** Checked again in better light and can see that the 2.25" is just the last foot or so, where it flares out slightly. The stock pipe size appears to be 2". So I will go with 2.25" for my new system.
I would like to hear what size exhaust other 3RZ 2.7L engine owners are going with.
RE dealer pricing on this item- it is worth it to print out lower online prices and give your local dealer the chance to match it. Sometimes they won't go quite as low, but you also need to factor in shipping charges. My experience lately is that with the slow economy they are more amenable to working with you, some cash flow is better than none at all!
Old 11-03-2008, 05:20 AM
CDUFF7's Avatar
Anyone know if there is any problem installing this on the 4Runner 2.7L ? Seems it should be the same exact thing.....
Old 11-03-2008, 05:39 AM
96redtoy's Avatar
They are the same thing you should not have any problems doing that
Old 11-03-2008, 05:52 AM
CDUFF7's Avatar
Thanks! Do you guys think this will add a little power or even a deeper exhaust note? I am almost ready to get on this since I would like to do this before a crack develops in my 3rz
Old 11-03-2008, 12:59 PM
riverrat's Avatar
I've been wondering this as well. The engines of course are identical, but some of the aftermarket 3RZ headers fit Tacomas but not 4runners- I think because of interference with a passenger side frame member.
But the stock Toyota mini-header is the same dimensions as the cast version, and apparently fits the same downpipe. So I'm guessing/hoping the mini header will fit my 4runner...I plan to buy a junkyard one unless the dealer can match $170.
Old 11-03-2008, 01:10 PM
96redtoy's Avatar
Let me know if the dealer matches your price
Old 11-03-2008, 01:28 PM
TOYOTA 1's Avatar
i wish i had known about this before buying a 330 dollar header
Old 11-03-2008, 11:27 PM
CDUFF7's Avatar
Can't wait to see the install pics, step by step. This has got me excited!!!
Old 11-04-2008, 03:24 AM
96redtoy's Avatar
should be here by thursday can't wait
Quick Reply: OEM mini header install for 2.7L*(Pics)*
