O2 sensor - change both if one goes bad
Old 03-15-2006, 11:21 AM
nees1212's Avatar
If one O2 sensor goes bad, would it just be wise to change both? I got a check engine light yesterday, so I took it to Autozone. The code came back as the O2 sensor, but I can't remember which one. It has 135,000 miles on it, and I have no clue if they've ever been changed as I just bought it. With one going bad now, my thought is that it's just a matter of time before the other one goes. Or, should I just go back to Autozone, figure out which one it is, and order than one?
Old 03-15-2006, 11:31 AM
Bob_98SR5's Avatar
yes, take it back and get the code. there is a different code for each 02 sensor. search obd codes here or on google. also, i wrote a tech writeup in the maintenance forum on changing out your 02 sensor
bob
Old 03-15-2006, 01:01 PM
eric-the-red's Avatar
I would just change the one that's gone, you're not saving much labour by replacing both now. Leave the one that's still working until it goes.
Old 03-15-2006, 01:26 PM
nees1212's Avatar
bob
I've got the writeup and code list from here. I was able to find that. I just wasn't sure if it was common that one would go out followed by another.
Old 03-15-2006, 03:53 PM
MTL_4runner's Avatar
The one before the cat often goes far more quickly than the one after the cat.
I would only replace the one that caused the code.
Old 03-15-2006, 04:12 PM
Jdizzydub's Avatar
I had the same thing happen to my 97', but shortly after I had replaced it my check engine came back and I was having throttle problems. I pulled the code for bank one sensor one(the one I had just replaced). For some reason the Bosch style doesn't read o2 right; I swapped it out for Walker and by looking at them, they are two totally different styles. Everything is all go now and my baby is Runnin' strong.
Eggslinger
06-08-2019 03:32 PM
Yotadawgjr
10
08-23-2015 10:51 AM
smiley52
07-11-2015 05:16 AM
Huntingtruckcletus
07-08-2015 05:26 PM
wilbertd
07-06-2015 07:39 AM
Quick Reply: O2 sensor - change both if one goes bad
