O2 Sensor....bosch?
Old 04-04-2004, 06:51 AM
AF1
AF1's Avatar
O2 Sensor....bosch?
I just bought a universal bosch o2 sensor.....I have read that a few people do not like them...think I should take it back and get Denso?
Old 04-04-2004, 07:13 AM
hypnotoad's Avatar
I don 't trust anything called "universal" - might work just fine, but my peace of mind comes from OEM (for most things)
Old 04-04-2004, 09:35 AM
Yoda's Avatar
Most O2 sensors put out the same voltages because of the way they are designed. "Universal" usually means it does not have a connector attatched and you crinp your old one onto it. These are usually 1 wire type of O2 sensors (I don't think I have ever seen a universal 2, 3, or 4 wire sensor). It makes sense.....One universal number to stock instead of 100 of the same sensor with different connectors for different applications.
Old 04-04-2004, 10:19 AM
Waterboy's Avatar
I've used them before, they work great. That is as long as you don't mind splicing the connectors to save $40 off the price.
Old 04-04-2004, 10:23 AM
AF1
AF1's Avatar
I don't mind splicing......I have not looked at the old one yet and know there is 4 wires...the new one has four wires two white and think the other two are black and grey....hope my old wires are same color so I do not have to guess...LOL
Old 04-04-2004, 11:55 AM
MTL_4runner's Avatar
There's not much difference between the Bosch and the Denso sensors. Almost all O2 sensors are design to output voltage in the same range and any slight variation will be compensated for by the ECU. Other than connector, there really is no difference.
Old 04-04-2004, 06:21 PM
Gadget's Avatar
www.urdusa.com has real DENSO O2 sensors that will fit your truck perfectly at a kick ass price!
Gadget
Old 04-04-2004, 06:46 PM
Gadget
That is a good price!
Old 04-05-2004, 07:45 AM
eric-the-red's Avatar
I put one of the Bosch universal sensors in my '93 4Runner last year, works fine. As for the wiring the colours are not the same but the instructions come with a chart showing which colours to match. Simply cut of the factory connector from your old one and connect it to the new one.
