O2 Sensor
Old 08-08-2006, 01:47 PM
TFJ-4runner's Avatar
O2 Sensor
The check engine light came on about 3 weeks ago. We had the code cleared once we knew it was the o2 sensor. about 5 days later it came back on so I reset everything by disconnecting the battery. Now it just came on about an hour ago while on the highway. Is it time for a new o2 sensor?
Specs:
2000 4runner SR5 2wd around 130,000 miles
All input is appreciated.
Old 08-08-2006, 01:53 PM
mastacox's Avatar
Specs:
Have you inspected the sensor for any wierd build-up? What about the wires/connection to it?
Old 08-08-2006, 02:00 PM
I have checked the wires and they seem to be fine. I haven't messed with the sensor because I haven't found a good write up on cleaning and inspecting it yet.
Old 08-08-2006, 02:14 PM
Spanky's Avatar
did you search hard enough?
Old 08-08-2006, 02:21 PM
Probably not, I have been busy preparing for school. Plus I belive I'm in the right place to get advice on this problem I'm sure. I'm here to learn.
Old 08-08-2006, 02:31 PM
Spanky's Avatar
use the search button up there, its bright, its yellow, it blinks, and its kinda pretty too!
Old 08-08-2006, 02:38 PM
MTL_4runner's Avatar
If you got an OBD code for an O2 sensor it was probably code P0136. Do a search on that and you'll get lots of info on that. To answer your question, more than likely yes, if you reset the code and it came back, you should replace it, but you better know what the code number was first.
Old 08-08-2006, 02:55 PM
Elton's Avatar
if you do get a new one order it from here there $79
Old 08-08-2006, 03:07 PM
Thank you guys for the help. I'll put it to good use.
Old 08-08-2006, 03:31 PM
wjwerdna's Avatar
i was told several times by dealer and autozone that my o2 sensor was bad... searched code here, dirty maf, so make sure you know what code it is, for me $3 cleaner vs CA emissions O2.... not $79
Old 08-08-2006, 05:09 PM
99SR5's Avatar
i had to replace my O2 at 130K so that might be it. its easy to replace it unless you have mud under your truck like i did so if you do just get some shop glasses
Old 08-14-2006, 11:53 PM
mywomanstaco's Avatar
in my own very recent and rediculously frustrating experience i have found it to be a much better decision to pay the $30-50 and have a toyota dealership do the diagnostic and tell you EXACTLY what part (with part numbers!!!!) it is you need. then go searching for a better deal from suppliers that are very active in this forum. instead of going to autozone or any other little garage with a code reader and playing the guessing game like i did. my initial CEL left me with 4 codes!! anything from insufficient coolant temp to closed loop fuel system error. i thought i was being smart and saving money by figuring it out on my own. the truck hasnt been driven in 3 months and ive bought 2 sensors that werent the problem and arent returnable. oh ya, make sure you know if its cali-emissions or not!! means the difference between an $80 O2 sensor or a $150-230 air fuel ratio sensor (cali)!!
moparbay
03-10-2023 03:50 PM
jb451
7
10-07-2022 06:58 AM
Kreedy1
09-08-2015 06:33 PM
zz_denis
09-06-2015 03:43 PM
moparbay
09-03-2015 12:48 PM
Quick Reply: O2 Sensor
