o2 censor check engine light
Old 07-23-2012, 11:39 AM
bajayata's Avatar
i have an 95.5 tacoma 2.7. this last weekend i removed the catalytic converter and welded in a cat delete pipe. now my check engine light is on. from what ive been told is that the o2 censor on the down side of the cat is just to identify that there is a cat. well theres not. so is there anyway to bypass that and turn the check engine light off?
Old 07-25-2012, 07:39 AM
mt_goat's Avatar
So you do have a down stream O2 sensor (after the cat) or not?
Old 07-26-2012, 03:07 PM
bajayata's Avatar
yes i do have one. there is also an upstream o2 censor. so 2 all together. i was told by a friend to disconnect the battery and it should turn off. so i did and it turned off. but a few miles down the road it came back on.
Old 07-26-2012, 05:15 PM
mt_goat's Avatar
If your code is a P0420 this will turn off the CEL. http://www.urdusa.com/Electronics-Re...kvp6i7pdd47fl7
Or you could just put your cat back on
Old 07-26-2012, 10:06 PM
TheDurk's Avatar
Originally Posted by mt_goat
If your code is a P0140 this will turn off the CEL. http://www.urdusa.com/Electronics-Re...kvp6i7pdd47fl7
I think you meant P0420. And that is almost certainly what he is throwing.
Old 07-27-2012, 04:02 AM
mt_goat's Avatar
Yes, thank you Durk, corrected above P0420. See... the URD sim works so good for me I forgot the number.
BTW I have a cat, but not a factory cat, and still need the sim.
bigjstang
08-25-2021 12:41 AM
06-01-2021 01:51 PM
Kalihi,HI
07-09-2015 04:29 PM
God's Bounty Hunter
07-08-2015 12:54 PM
colinmil
07-06-2015 04:03 PM
Quick Reply: o2 censor check engine light
