Non-gen3 4runner front seats: Retrofit?
Old 06-02-2011, 05:50 AM
profuse007's Avatar
I have a base model 4cyl 4runner and I never liked the seats. The seat is bench-style, very flat and not a bucket style.
I want to replace it with another set of seats, preferably bucket seats.
I was thinking of 03+ 4runner cloth seat or any other seat with great comfort.
Anybody with experience retrofitting seats? Any ideas?
Old 06-02-2011, 11:58 AM
Nervo19's Avatar
Before someone says something rude, I'll gently advise you to do a search for "seat swap." Most of what you'll see will pertain to earlier generations of trucks. Generally you can swap your bench seat for same year range 4Runner seats easily. The tech will be in the searched threads. I haven't done it yet as I'm lazily searching for some gray SR5 seats for a first gen 4Runner. The seats from my 2000 will fit in my 1989 with modfication on one bolt.
Old 06-04-2011, 10:28 PM
Man4God's Avatar
Basically anything can be made to work...so long as you got a welder or someone you know does.
I have seen Acura RSX seats in our 4Runners.
Old 04-07-2012, 11:45 PM
Man4God's Avatar
Old post...but newer info.
http://www.toyotanation.com/forum/79...s-my-taco.html
This guy put mid 90s Grand Cherokee seats in his Taco. No less, he found powered ones. Cut the plugs out of the donor truck and wired a power and ground and he was off and running. Other than that, he just put the seats where he wanted them, drilled new holes and used new hardware. Then plugged the old holes.
Me personally, I am going to look for manual seats because I am tired of the fascia getting knocked around. Found a good deal on a pair...may pull the trigger.
Old 08-20-2012, 11:08 PM
Man4God's Avatar
FYI, this manual seat trial was a disaster. I would be better off trying to find manual racks from a 4Runner and then finding other seats to fit with slight modification.
The Jeep seats were much more narrow (mounting spots) than the 4Runner. Lame. I liked the seats otherwise.
06-01-2021 01:51 PM
lledwod
08-30-2016 01:03 PM
MTLroadierunner
07-15-2015 12:58 PM
musashi86
California SoCal
07-07-2015 03:31 AM
toyoda8488
07-05-2015 10:18 PM
Quick Reply: Non-gen3 4runner front seats: Retrofit?
