Old 03-30-2016, 11:54 AM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Toyota Tacoma Engine Guides
Print Wikipost
New Timing Belt Water-Pump 5vz-fe 3.4L Write-up for Review
Old 07-14-2018, 07:24 AM
  #61
aowRS's Avatar
Originally Posted by 83
Well I ended up paying someone. Moment of weakness. He installed my parts. 240,000 miles, he said the water pump was original. Belts had been replaced at around 100,000 and I assumed they did the pump, but according to the mechanic, nope. It was leaking a bit but the belts looked fine. No oil leaks. I said "well it's probably the last timing belt/water pump job this truck will have" and he sort of looked at me, so I said "or not?". He says he's got two other customers with 3.4s who are the original owners and keep up on maintenance, and both are over 400,000 miles. Pretty cool.
Check my signature. I'm trying to get my money's worth by shooting for 500,000 miles...
Andreas
Old 07-16-2018, 08:09 AM
  #62
83
83's Avatar
Time will tell. I worry more about what else will fall apart along the way...but it’s a Toyota. I’ve put 50k on this since buying it. I’m only just now spending any real money on it with the timing belt/water pump job and right now sitting in Les Schwab getting new tires. It hurts...but it’s worth it.
Old 01-09-2019, 03:22 PM
  #63
83
83's Avatar
I've got the pulley holder for doing this job up for sale right now in the classifieds, un-used.
Old 08-15-2020, 07:56 PM
  #64
tommul's Avatar
Is the Timing Belt-Water-Pump write up still available? Would love to have a look at it.
Old 08-23-2020, 06:04 AM
  #65
83
83's Avatar
Click the link the first post.
Old 04-09-2021, 09:16 PM
  #66
Ivans’s's Avatar
Originally Posted by Pipsisiwah
When I replaced the water pump and timing belt on my 1998 Tacoma 3.4L engine I had to remove the AC pump and the bracket that holds it to the block. Then I had to tie the AC pump up high out of the way to gain clearance to one of the tensioner mounting bolts (can't recall which one right now). OTHERWISE IT WAS IMPOSSIBLE TO REMOVE THE TENSIONER ASSEMBLY FROM THIS ENGINE!Other folks have also had this problem. You may want to add this step to your discussion. I cannot speak for anything other than a 1998 3.4L engine.
Detaching and reattaching that bracket took me about 2 hours total and an assortment of wrenches and sockets, and a fresh start the next morning to reattach it to the block.
Just completed timing belt/water pump replacement & was able to do it without removing the A/C compressor or its bracket. Removed the (2) 10mm bolts holding the starter wire located just above the front of the oil pan. By pushing the loose harness toward the driver’s side, you can access the rear TB tensioner bolt going up from underneath between the frame & oil pan using a (3/8”) long wobble extension & universal joint socket adapter. Prolly even be easier with (1/4”) drive? It’s not easy to get to & remove this bolt, even harder replacing it. To make it easier, l slid the bolt into the tensioner housing & held it in place with a piece of tape (see pic below). This enabled me to hand thread the front bolt half way in to secure the tensioner in place, then slide the extensions back up from underneath & the rear bolt was already in place to be screwed in. Hope this helps, as this is probably the trickiest part of the whole job. ✌️
(l used the old tensioner for the “photo op”)
Old 08-07-2021, 03:11 PM
  #67
Hosee80's Avatar
Question Age a consideration to change timing belt
My tacoma is 19 yrs old (2002) but mileage is low (67500). Is the decision to change the TB/water pump based solely on mileage or is age a consideration?
Old 08-08-2021, 01:48 PM
  #68
2ToyGuy's Avatar
According to the Toyota Parts site I found, they specify every 60,000 miles.
If you check it, and it's at all frayed, damaged, missing ridges on the underside, you can see threads sticking out ANYWHERE, oily, or ANY other kind of damage is found, replace it immediately, regardless of the milage.
From what you gave as far as age and miles, IF I WERE YOU, I would replace the belt and water pump right away. Without delay.
I have a funny feeling the belt may in pretty bad shape by now. I'm not sure if that's an interference engine or not, but if the belt breaks while the engine is running, especially much above idle, it can cause some severe engine damage.
Beware of a damaged belt. If it breaks it can cost you a heck of a lot more than the price of a belt/water pump kit does.
Good luck!
Pat☺
Old 08-08-2021, 02:30 PM
  #69
aowRS's Avatar
From a mileage standpoint, you're completely fine. It wouldn't hurt to remove the upper timing belt cover and inspect it for actual cracks, etc.
As a counterpoint to the other (somewhat alarmist) response - the 3.4 5VZFE engine is a non-interference design. Should the belt break, you will not have a destroyed engine.
- I've owned my truck since new. Did the first timing belt job at 171,000 miles - belt (and accessory belts) looked perfectly fine.
- Did the second timing belt job at around 350,000 miles - belt (and accessory belts) looked perfectly fine.
- I'm now at 490,000 miles and look forward to doing the THIRD timing belt job somewhere around 520,000 miles.
Andreas
The following users liked this post:
Ivans’s (08-15-2021)
Old 08-09-2021, 01:20 PM
  #70
Hosee80's Avatar
Changing timing belt
Thanks for the messages-both are informative. I think I will take a look at the belt and see its condition, if it looks ok, I may wait a while since the engine probably would not self destruct if it failed. I appreciate both responses.
Old 07-02-2022, 12:05 PM
  #71
skjos's Avatar
Massive update to the write-up with new tip/tricks, and it now includes replacing the camshaft and crankshaft seals, as well as the tensioner and radiator.
old87yota (07-07-2022)
Old 07-02-2022, 01:18 PM
  #72
aowRS's Avatar
Awesome. I used your write up the last time, and will reference it again in about 9,000 miles.
Andreas
Old 07-03-2022, 06:09 PM
  #73
Hosee80's Avatar
Unhappy Services and ready to go
I looked at the timing belt and there were places where metal showed where rubber was missing. Had it changed out and the water pump showed signs of having a small leak. Also had the thermostat replaced, crankshaft seal, camshaft seals, belts, hoses, flushed old antifreeze and installed new red toyota fluid, rollers and idlers. Should be ready to go (also had fr rotors and pads replaced, rear shoes with oem), new Bilstein 4600 fr/RR, lower Ball Joints, 4 wheel alignment. Changed oil/filter, replaced all fluids in differential, trans, trans case , new per steer fluid and brake /clutch fluid changed with aamsoil products, NOS plugs/wires. Pretty well ready to go. Most all maint items good ( new fuel filter, plugs, wires, tires, clutch, throttle body cleaned). Now its going down to dealership Tuesday as I am selling it. Very clean with 68K miles. Asking a fairly high price. Hope somebody likes it enough to pay it.
2ToyGuy (07-04-2022)
Old 10-06-2022, 04:38 PM
  #74
squirrel 99's Avatar
skjos; thank you, thank you thank you for all the hard and tedious work to make this superb write-up! Did mine a few years ago with this. So satisfying to hit the starter afterwords and half the engine purr...! skjos you are the best! Greetings from Spokane
2ToyGuy (10-07-2022)
Old 11-05-2022, 07:31 PM
  #75
Timmah's Avatar
I'm not much of a write-up guy, I'm obviously a fan of video, but the write-up looks to be very well done. I've got a couple videos on this subject. Part 2 came about because we had to go back in to investigate a noise that surfaced. We also included some helpful tips in Part 2, mainly an easier way to get the timing belt on, so it's worth a watch. Happy Wrenching!
cgilley
12-26-2011 05:27 PM
EddieFin808
05-04-2011 01:00 PM
KBump
08-25-2010 10:17 AM
bretskie27
04-20-2010 05:57 PM
2toyman
11-23-2007 08:36 PM
Quick Reply: New Timing Belt Water-Pump 5vz-fe 3.4L Write-up for Review
