new idle issue problem P0505
Old 09-05-2011, 01:12 PM
Ned
Ned's Avatar
Exclamation new idle issue problem P0505
Well if you read my other post about a 3500 rpm idle, (Topic here) you know the history. I got a used throttle body and swapped them out. Now I am getting a code of P0505. I never got this code before. So I took the original IAC valve off and put it on the replacement TB, but I still get the same code and it idles low/ rough. Any idea why it would just start giving this code when it never did before?
Old 09-05-2011, 02:11 PM
86yotaswampmonster's Avatar
I would take it apart and I clean Every hole In the throttle body and check ur vacuum lines
Old 09-05-2011, 04:32 PM
Ned
Ned's Avatar
yeah, i'm going to do that. It just doesn't make sense to get the code when it never did before.
Old 09-05-2011, 04:43 PM
Ned
Ned's Avatar
Can a bad TPS cause this? If so, I might swap out the original TPS as well...
Old 09-05-2011, 04:58 PM
It might be the tossed. But ill tell u Toyota engines are run so much on vacuum . I have alot prob with vacuum on my truck as well right now.
Charecter1
11-06-2023 10:08 AM
bigjstang
08-25-2021 12:41 AM
smiley52
07-11-2015 05:16 AM
Jnkml
07-06-2015 01:20 PM
Quick Reply: new idle issue problem P0505
