need some help.
Old 07-12-2007, 02:27 PM
hatchbox's Avatar
need some help.
1996 Toyota tacoma,
4wd V6
About a month ago, it through a check engine light. No symptoms, just erased the code, and it stayed off till 2 days ago.
Then today on the highway i came to a stop and they engine idled at 3k. Even if i kept the clutch in.
Stopped and popped the hood and the ground from the battery to the chasis snapped.
Did i fry a sensor?
Checked the codes its throwing 3
*P0110 Intake air temp circuit malfunction.
*P0120 TPS/ Petal position sensor. Sensor A Ciruit Malfunction.
*P0510 Closed Throttle Postion Switch.
Tried a autozone TPS
Tried a known working mass air flow sensor.
No luck.
Any ideas?
Old 07-12-2007, 02:31 PM
blink's Avatar
Id check and clean all your grounds. I know on my taco, I had a loose ground that caused the ecu to throw weird codes and run poorly.
Old 07-25-2007, 06:51 PM
hatchbox's Avatar
Checked grounds,
swapped out maf, tps. cleaned throttle body.
Could this be a IACV problem? If so how would i clean/adjust it and where is it located?
Old 07-26-2007, 01:32 PM
hatchbox's Avatar
Originally Posted by hatchbox
Checked grounds,
Nothing?
Old 07-31-2007, 04:45 PM
hatchbox's Avatar
http://www.4crawler.com/4x4/CheapTricks/TPS/index.shtml
Just did that tests. I know i dont have a 95, but a 96.
But i should have continuity from IDL - Ground with throttle closed right?
I have battery voltage at that wire, but no countinuty from IDL to ground. With the throtlle in any position.
Old 08-04-2007, 06:42 PM
hatchbox's Avatar
anything at all?
Old 06-30-2010, 05:58 AM
Runnerfan's Avatar
Did you ever solve the issue? What was it? How did you fix it?
zytra
01-24-2019 03:16 PM
Firefightersink15
11-23-2015 10:32 PM
Shagool22
09-28-2015 07:53 PM
fountain
09-28-2015 03:04 AM
LotOMiles
09-14-2015 11:45 PM
Quick Reply: need some help.
