Need instructions for progamming 98 4runner keyless entry
Old 09-02-2009, 12:01 PM
BMWToyotaMan's Avatar
Just picked up a new keyless entry for my 98 4runner. Instead of paying the 50 dollars they charge I wanted to setup the keyless entry myself.
My car has the factory alarm.
I searched and found nothing on this matter besides links to websites that no longer exist.
Anyone have the instructions?
Thanks,
Jeff
Old 09-02-2009, 12:21 PM
Found the instructions, wow so easy. I can't believe they charge so much for this.
Remote Control Programming
The RS3000 ECU can be programmed to be operated by as many as 4 remote controls. Additionally, the provided remote controls top and bottom buttons may be assigned to operate another 1998 or 1999 model vehicles RS3000 security system, and both buttons can be programmed to operate the system in one vehicle. To add or delete a remote control, you must access the RS3000 ECU (computer), location varies by vehicle and model.
To program (add) a remote control to the system:
1: Insert the key into the ignition switch and turn it to on.
2: Press and hold the ECU's programming switch for 3 seconds. The status monitors LED turns on for 5 seconds.
***You must perform the next step within 5 seconds***
3: Press and release a remote controls top or bottom button. Either button on your remote control can be programmed to operate the RS3000. The status monitors LED turns off. The piezo chirper chirps once. The exterior lights flash once.
4: Turn off the ignition. The ECU will now operate with the remote control just programmed.
Note: The factory preset operation is for the top button on both remote controls to operate your system; the bottom button is not programmed. To prevent accidental erasure of a remote controls code, we recommend that you program all your remote controls at the same time.
http://www.parksoffroad.com/tacomamo...oteprogramming
Old 09-02-2009, 04:17 PM
Ironmike4x4's Avatar
Just an FYI, the ECU is mounted underneath the driver's seat. It's a black box and you will see a little hole on the side towards the door. Just get a pen and press it and do the above steps.
Old 09-02-2009, 05:35 PM
bgmac's Avatar
this would make a good **sticky!
Old 09-03-2009, 09:21 AM
ESQ
ESQ's Avatar
I second the sticky!
Old 02-15-2013, 11:54 AM
bamaboy1285's Avatar
Can anyone tell me where the actual "chirper" is. Sometimes mine works and sometimes it doesn't. I am assuming that it is just a bad connection somewhere, but I cant find the thing!!
Old 01-01-2014, 10:33 AM
zarguy's Avatar
When I push in the green button on the side of the ECU, I don't hear or feel any click. Is the LED mentioned on the ECU, or on the dash? No joy here
1998 4Runner Limited
Lynn
Old 01-12-2014, 03:09 PM
r34sklnnsn's Avatar
I didn't see a light on mine either, I just pressed it and followed the steps above and it works. Just make sure you have the right fob. Mines a 98 and the fob is black.
Old 01-12-2014, 04:13 PM
zarguy's Avatar
OK I found where the LED is. It's on the console between the 2 front seats. It says Toyota Security.
I didn't have any success with programming my new remote. I think the Immobilizer has been disabled on my 4Runner. Is the LED supposed to constantly blink to indicate that the system is working? On my 2005 Sienna, the LED constantly blinks.
Lynn
Old 01-12-2014, 06:28 PM
Dropmytaco's Avatar
Picked up a brand new key fob off eBay for my 01' and the instructions sent me to http://www.programyourremote.com/cla...se.asp?cid=283 but there's instructions for the older models too
Old 01-25-2014, 01:08 AM
4x4boating's Avatar
Nice info-link THANKS 4 SHARING!!!
Old 01-28-2014, 04:40 AM
fibercarbon's Avatar
where is the best place to buy brand new keyless with remote start button on the bottom for a 1997 4runner sr5
Old 01-05-2015, 05:01 PM
pedrojr80's Avatar
hi guys i hope someone respond to my question since the last person who respond go back to 01.28.2014 almost a year ago. any who i have try to program my remote control on my 98 runner but i havent have any luck. the light on the alarm blinks after holding the ecu reset botton and it blinks then a press the top botton on the control and nothing the light goes out and no sound no nothing. is the security light suppost to be blinking whe the truck is off? cause my it dont turn on just when i try to set up the remote control other than that the lights is off from the rs3000 system. i might have a problem with the system but i dont know since there is no info on the rs3000 system diagram or something. hope anyone can help me.
thanks!
Last edited by pedrojr80; 07-09-2016 at 08:15 PM. Reason: Problem solve! The rs3000 was disconnected from the plug that plugs to the window and door switch. Its a blue connector
Old 06-27-2016, 02:36 PM
richter333's Avatar
Location of RS3000 ECU Computer on 95 4Runner
Anyone know where this computer is located on a 95 Toyota 4Runner? I'm trying to program a new remote door opener.
Flying91
45
04-11-2024 04:39 PM
sandyota
02-04-2021 11:16 AM
icentropy
09-16-2020 02:47 PM
RaginAsian91
Engine Swaps
03-30-2019 09:17 AM
BeMiceElf
10-10-2015 09:40 PM
Quick Reply: Need instructions for progamming 98 4runner keyless entry
