Need help with alarm... Lost transmitter ...cant start
Old 10-06-2005, 04:56 PM
WT
WT's Avatar
Originally Posted by Amir904
i tried jumping it, its still clicking... dead battery?
Can you tell were the clicking is coming from ?? is the Alarm still hooked up it could be its relay your hearing, just a guess. If the brains disconnected the relay for the starter disable could still be stopping your from starting her up.
May try locating that relay under the dash by the stearing colum or under the hood somewhere and disconnecting it maybe that will help.
Old 10-06-2005, 05:16 PM
Fink's Avatar
Yeah, that's what I would do. Odds are your relay is still hot and its not letting it start...find it, disconnect it and then try that. If that doesn't work sounds like a good opportunity to get yourself an Optima.
Fink
Old 10-06-2005, 05:26 PM
Amir904's Avatar
ya, i already have an optima on my 98. this problem is occuring on my 96. tom ill try to take out all the fuses under the dash that are hooked up to the brain. there are about 4 of them.
Old 10-06-2005, 05:29 PM
Fink's Avatar
Take your Optima out of your '98 and put it in your '96 and if that doesn't work then you know it's your relay.
Fink
Old 10-07-2005, 08:39 AM
  #25
Amir904's Avatar
is there another way to test it?
Old 10-07-2005, 10:08 AM
  #26
Fink's Avatar
Are you planning on keeping your alarm installed? If not just cut the wires going to the relay and then try it...if that doesn't work then its your battery. Taking the battery out would probably be your best bet as that would only take about 10 minutes and a 10mm socket...if you cut the wires to your relay you'll have a bunch of open wires hanging around your engine bay. If it was me I'd either just replace the battery in the '96 (depending on age) and then go from there.
If the battery nor the relay solve it then I think you may just have to get another remote and do it that way. Sounds like you might be better off tracing the problem you're having as of now, take it somewhere and get the entire alarm removed from the vehicle and then if you so chose, find another newer alarm that has a kill switch or fuse that is easily removed if you need to do so in the future. That is just what I would recommend...sounds like this thing is taking control of your rig completely.
If you need alarm suggestions, DEI and Code Alarm are both really good brands, I had a Code Alarm on my 2nd gen and I loved it, very reliable and never failed me.
Let me know how it all turns out.
Fink
Old 10-07-2005, 05:04 PM
  #27
Amir904's Avatar
ok, took out the battery, took it to auto zone, got it charged and popped it in. it started no problem. im just gona keep the main connection to the brain unplugged until i find a transmitter and program it. thanks for the help Fink.
Doug4320
03-24-2018 10:11 PM
jerusry
10-19-2015 05:28 PM
Poncho0206
07-10-2015 06:21 PM
Huntingtruckcletus
07-08-2015 05:26 PM
Suprarossa
07-06-2015 05:21 AM
Quick Reply: Need help with alarm... Lost transmitter ...cant start
