Mysterious cut lines
Old 03-18-2012, 07:43 AM
madcanvis's Avatar
Hey Guys-
I could use a little light shed on these two lines. My 4Runner runs cherry. Great MPG's, power, 4wheel drive. All is great. I bought this back in June and after preparing for some PM I noticed this...
there are 2 lines mounted to the firewall (just above the blue wire tie in left of photo) that have been hacked off. These go down along the frame and then cut again (or rusted off). I have no clue as to what they were for... Picture is here...
https://www.yotatech.com/members/mad...photo0032.html
4runner 2000- 3.4 5v fze, automatic trans, w/ 4wd
Thanks.
Old 03-18-2012, 09:02 AM
pattycakes77's Avatar
Do you have a rear heater? Those might be the rear heat lines but I would think that if they were cut you'd have a coolant leak.
Old 03-18-2012, 10:33 AM
aowRS's Avatar
I would think rear heater lines as well. Here's a thread I wrote years ago: corroded heater lines
Andreas
Old 03-18-2012, 01:07 PM
drpdmazda's Avatar
definately the old lines for the rear heater in the center console. i just bypassed mine earlier in the winter due to a leak.
Old 03-18-2012, 01:11 PM
madcanvis's Avatar
Sweet. Thanks guys. Both answers help. I do have the rear heater and it works well enough and no leaks as this was "fixed" at least a year ago. So now I have to climb under there and see if the hose was re-routed by the PO. Or perhaps just "blowing" heat (from somewhere else?).
Old 03-18-2012, 01:23 PM
enapa's Avatar
It would still blow air, might be warmish. Those lines would be for the coolant to run through the rear heater core which would make the air actually warm/hot.
sanctfy
All Other Toyota Swaps
09-15-2015 02:52 PM
pyramid
07-30-2015 10:05 AM
Hiluxtrucha
07-22-2015 10:00 AM
Fundy Rider
07-16-2015 01:35 AM
crashburnoveride
07-10-2015 06:39 AM
Quick Reply: Mysterious cut lines
