Misfire 2 & 5
Old 09-27-2012, 06:39 PM
J2F42C's Avatar
Have you had a mechanic test the fuel pressure?
The codes are thrown at all speeds (idle to 70MPH+) correct?
Old 09-28-2012, 01:00 PM
craist's Avatar
Yes it does at all speeds.
Fuel pressure has been tested and is ok
Old 09-30-2012, 02:49 PM
craist's Avatar
More things tested.
Spark plugs - grounded each and checked for spark - OK
Crankshaft position sensor - OK
Camshaft position sensor - OK
O2 sensors - OK
Throttle position sensor - OK
Swapped spark plugs around - No change
I think what is happening is that it is running lean causing the misfire.
Any other advice?
Old 09-30-2012, 03:47 PM
Texas_Ace's Avatar
Originally Posted by craist
More things tested.
O2 sensors - OK
Any other advice?
Running lean is possible, I considered that, or running too rich. It is VERY odd for it to start misfiring on those 2 cylinders at the same time though.
Old 10-01-2012, 06:09 AM
  #25
craist's Avatar
I know it is running lean. Toyota did a four gas analysis test on it and like I mentioned in original post. It should be 14.7-1 and mine is 28.38-1.
Old 10-01-2012, 06:24 AM
  #26
Texas_Ace's Avatar
It is not that lean for sure, it will not run that lean. My truck will misfire and have one heck of a bad day if it gets much above 16.5:1.
You should also get a code if it is running that lean and you said you don't have a CEL.
Old 10-01-2012, 07:31 AM
  #27
J2F42C's Avatar
What was the fuel pressure reading? It may be a regulator problem.
Old 10-01-2012, 08:06 AM
  #28
Jomoka's Avatar
Yeah, a reading that lean is more of an indication of a leak in the exhaust system. The engine just won't run if it was actually that lean.
Old 10-03-2012, 02:23 PM
  #29
craist's Avatar
fuel pressure is 60 psi
Timing is fine, crankshaft key way is fine, timing advance is fine.
I took it to a different mechanic, one I trust. His snap - on professional stand up diagnostic machine can only read one bank (IE it is only getting data from one side of engine) and without that information he doesn't know where to go and can't fix it.
I have run out of things to test.
anyone with any other ideas?
  #30
craist's Avatar
ok if that is so, can that be causing my problems?
Old 10-03-2012, 03:45 PM
  #31
Texas_Ace's Avatar
It could be a problem or it could have been a sensor/testing error. Or a leak at the bung where they put the wideband sensor, lots of possibilitys. For it to read that lean you would hear the leak for sure.
60psi fuel pressure is too high I am pressure sure. Usually it is around 43psi.
Old 10-03-2012, 04:27 PM
  #32
j2the-e's Avatar
Check the valve clearance! No its not done as regular maintenance at the dealer. Pull the valve cover on the easier side and specifically check the exhaust valves under the flat side of the cam with a feeler gauge. The spec is under the hood. They tighten over time and will get to the point that they wont close all the way when hot. Check it and fix it before you burn a valve so you can avoid a complete tear-down and valve job.
Old 10-03-2012, 06:20 PM
  #33
J2F42C's Avatar
Fuel pressure is too high as TA said earlier. When you pull the vacuum line off the regulator, can you smell gas?
But also do a smoke test and/or spray test on the exhaust. I do know of someone who had a tiny hairline crack in their exhaust manifold that caused a misfire once in a Lexus ES300.
Old 11-08-2012, 06:57 AM
  #34
craist's Avatar
Well as it turns out, Toyota didn't check the crank pulley bolt like I had asked and paid them to do. Long story short, pulley bolt had come loose causing all kinds of problems.
It has since been fixed. Thanks for all the help
Old 11-08-2012, 07:44 AM
  #35
J2F42C's Avatar
I am glad you got it figured out. I guess the bolt was loose from when the TB was changed last time. You were lucky that the loose bolt did not lead to bigger problems.
shooter86314
01-07-2016 07:05 AM
Firefightersink15
11-23-2015 10:32 PM
calderp
11-16-2015 02:49 AM
the_supernerd
10-01-2015 09:20 PM
larrys93pickup
09-17-2015 07:05 PM
Quick Reply: Misfire 2 & 5
